Old 11-16-2008, 05:00 PM   #1
Air Apparent's Avatar
Northern Illinois , Illinois
International Rally & Generators
I understand that there is a generator section at the International rally.
I'm interested in knowing if generators can be run through the night or are there specified times when it can be run and when it cannot. I use a CPAP machine for sleeping and would need to run the generator through the night. I'm also aware that 30 amp electric is available for $255 but I'm not sure that I want to be parked on asphalt in Madison for a week.
Also are there any other requirements regarding generators. I have a Honda EU 2000.
I'm interested in hearing from those who have attended prior International rallies and have stayed in the generator section.
Thanks for your input.
Dave
2008 Classic 34
Dodge Ram 2500 Quad Cab CTD
AIR #7317 WBCCI #1772 TAC-IL 1
Air Apparent is offline   Reply With Quote
Old 11-16-2008, 06:15 PM   #2
2007 25' Safari FB SE
Evergreen , Colorado
We attended our first Int. this year, the gen, section was on a grass section. They did run the gen. all nite,it worked out great.
Allen H is offline   Reply With Quote
Old 11-16-2008, 06:31 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Dave,
Contact your CPAP supplier and get a 12V dc plug.
Bill
Just my personal opinion
Old 11-16-2008, 07:25 PM   #4
Dwight's Avatar
1999 34' Excella
Joshua , Texas
You will also have motorhomes in the generator section.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 11-16-2008, 08:01 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I would think that the CPAP would run on the 3 amp that you get with out extra charge, especialy at night when most are not using any electric. Check the rating to see how many amps it needs.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-16-2008, 09:10 PM   #6
Miss Rivette
airedale's Avatar
1965 17' Caravel
Hell , Michigan
Send a message via AIM to airedale Send a message via MSN to airedale Send a message via Yahoo to airedale
I know I was in the generator section this year, and the people next to us ran their generator all night, Althought it was quite, it still kept me up most nights.
Laura Miss Rivette 2008
W8JUZ --......--
"Support Search and Rescue, GET LOST!!!!"
Operation "SAVE RUDY" Strike Team (Charter Member)
Check Out My New Airstream Blog
airedale is offline   Reply With Quote
Old 11-16-2008, 09:18 PM   #7
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
My CPAP draws <2 amps without the heater on' only 4.5 amps with the heater. While yours may exceed those figures, I find my trailer's house battery handles the draw-down without a problem. Having a 3 amp feed to your Univolt, if you have eliminated the worst of your phantom loads, there shouldn't be any difficulty running the CPAP, the refrigerator control board and the battery charger portion of the Univolt.
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 11-17-2008, 03:28 PM   #8
1998 28' Excella
Dolores , Colorado
Hello Bluebird;
I have been on a CPAP for past 4-5 years. I attended the International in Salem and paid for the electricity. Not sure for 6-8 days if it's worth the amount they charge. I have a 140 watt inverter that I run my CPAP through when I am boondocking. It works fine as it does not draw the batteries down. I do however carry a 3000 Yamaha generator when I boon dock.
Check out the registration form for the International. As a person that requires oxygen and CPAP at night I have been able to get my doctor to write a letter that qualifies as a handicapped and there should be discounts given for that. You may have to park on pavement because of the handicapped status which I know you don't want to do.
We keep debating upon the rally in Madison but will probably wait and go to Gillette, Wy.
BOB
Member Four Corners Unit
WBCCI # 10105
AIR # 28748
dogpound is offline   Reply With Quote
International Rally gryphon WBCCI Forum 6 01-25-2005 05:29 PM
International Rally & 30 amp obdaryl WBCCI Rallies & Events 1 03-04-2004 12:18 PM
Something New With the WBCCI International Rally? overlander64 WBCCI Rallies & Events 5 02-26-2004 05:21 AM
International Rally gwsullivan WBCCI Rallies & Events 29 09-27-2003 06:14 AM
When is the International Rally saxonsraven Our Community 8 03-05-2003 03:37 PM
