Closed Thread
Old 06-26-2012, 06:52 AM   #71
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by nvestysly View Post
For the 40% who do not use the internet they can obtain the printed copy of the membership directory via snail mail.
One can reasonably assume that as time goes on, that 40% who are Internet-challenged will drop to a lower percentage. And since they are already a minority (albeit a large minority at present) they should not be the controlling factor in how WBCCI information is disseminated.
The chairman does not refer to an elctronic/interactive map so I can only presume this would be a printed/stagnant map. While courtesy parking is a wonderful hidden gem within the WBCCI community, and we should all make more use of it, I find it interesting that we're considering a volunteer to "make a map." So here's the next suggestion... Make the same electronic member information available via computer/smart phone app so we can easily identify courtesy parking opportunities.
An excellent solution would be a Google Maps application, made available at the WBCCI website. This would not only allow easy updating as those who provide courtesy parking change, but also allow one to get directions to the selected site, even for those who don't use GPS. And, for that matter, the Google Maps app need not be limited to courtesy parking; Rally locations can be added, as well as caravan start/stop locations, Airstream dealers, etc., thus making the map a true visual WBCCI interface. Putting rallies and caravans on the map would require a commitment of time to keep the map up-to-date, but as users become more familiar with the map, rally and caravan organizers could add updating the map to their organizational duties rather than relying on a "map admin."
Plus, Google Maps allow further information to show up in a popup dialog box when you roll the cursor over the map stickpin, so information about courtesy parking hookups, length restrictions, seasonal availablity, whatever, can be added besides just the address. For rallies and caravans, the popup info can list dates, contact info and deadlines to register, etc.
The data would obviously need to be secure and only available to current members. There are any number of electronic login methods to verify current membership - most of us use them every day - when we login to check account balances, shop online, etc. Let's apply those same security measures to the member data and make it available to all members. Then the member numbers could be searched, the courtesy parking locations could be identified, renewals could be done online, and we'd be looking like a 21st century club rather than a mid 1970's club.
Hear, hear!
If the data is only available via a secure portal I don't see any need to obtain "permission" from the membership. The portal is simply the electronic version of the directory rather than a printed version of the directory.
This one I have to disagree with. Lots of people, whether Internet-savvy or not, are understandably cautious about the possibility for identity theft, invasion of privacy, and the like. Anyone who does not want their information to be available over the Internet should be allowed to opt out, in exactly the same way that one can have an unlisted telephone number at home.
However, those people who don't want their information listed on the Internet should consider the wisdom of having it listed in a hard-copy membership directory as well. That is also a permanent record, and can be obtained by non-members since there is no control over where a magazine goes once it's delivered to the addressee. The Internet listing has the advantage that once you fail to renew, your information would be removed, but with a hard-copy listing, back issues are still out there and so is your information, long after your membership expires.
I would suggest that for BOTH the hard-copy directory and the Internet directory, the solution is to add check boxes to the membership application and renewal forms, asking if the member wants his information to be published in one, the other, both, or neither place. The master directory at WBCCI headquarters would necessarily list everybody anyway and each Region and Unit would have a complete list of their members, but those members who don't want the information made available to other members should be allowed their privacy.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is offline
Old 06-26-2012, 01:24 PM   #72
HowieE's Avatar
Princeton , New Jersey
Images: 12
The idea of a map is the best advancement to Airstreaming I have heard of in a long time.
It would be great while traveling to see who was having a rally in the area I was passing through. It would be great to just open the map and see if there was courtesy parking near by.
I currently use this type of map while Geocaching. The map while quite a bit more extensive than what we could hope to set up in WBCCI, 1,720,000 points noted, clearly demonstrates what could be available. The example of a map can be seen here
Geocaching > Geocaching Maps
Scroll and let your mind wander at the possibilities
The limiting factor as I see it at this point is the server. But if a server can be found any unit or region could start the ball rolling by setting up there own local map that could be folded into others as they are generated if they all used a common form.
If a server were to be housed in Jackson Center and a committee of volunteers, like those that Mode here on Airforums, had remote access to it it would be a simple thing to administer. Those that wanted information on the map would submit it and a member of the committee would post it to the map thus maintaining a level of control that would have easy accountability
2004 Excursion 4x4
HowieE is offline
Old 06-26-2012, 01:39 PM   #73
Gainesville , Florida
Great ideas! But remember many who have the Internet and email do not use them very often or check for messages. This seems to be a problem with many units, where word of mouth seems to still be in vogue. Seems we need a way to encourage more usage. Someone I am sure will have a good idea. Jim
xrvr is offline
Old 06-26-2012, 01:54 PM   #74
HowieE's Avatar
Images: 12
Do you really think Mark Zukerberg was thinking about those who only occasionally turned on their computers while designing Facebook. Why should we wait for or be governed by those who want to be left behind?
How about a comment or 2 from those with the computer knowledge as to how this could be started.
2004 Excursion 4x4
HowieE is offline
Old 06-26-2012, 02:27 PM   #75
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The geocaching map is a great example of what could be done.
I am embarassed to admit that I have been a user of that site and had never seen that feature
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
RickDavis is offline
Old 06-26-2012, 03:27 PM   #76
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Lots of great points here. The mapping ideas are sooooo good, too.
I was stunned to read the percentage of members who are not online, too.
Skatiero is offline
Old 06-26-2012, 05:10 PM   #77
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
I suspect a lot more members are on line than indicated. It is likely a lot of members opted out of having their e mail addresses published in the directory because of spam worries.
13 Ram 2500 TD
Old 06-26-2012, 05:30 PM   #78
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Sounds like we need a survey to determine how many members who would use the service, before we spend the club money to develop a system that would work. Constant Contact could send it out to the 3,800 email addresses (out of 5,690 members we have).
dwightdi is offline
Old 06-26-2012, 05:48 PM   #79
The answers to that survey will depend on the data that would appear on the map. When the survey is put out, list all of the applications we can think of that the map would be used for. For example, there may be people who want caravans mapped out, but have little interest in courtesy parking. Or vice versa, but all of them who are interested in even one application add to the justification for trying it.
So, the data that I think should be on the map, just as a start and in no particular order:
Courtesy Parking; Rallies (especially recurring ones); Caravans (ditto); Airstream Dealers; Airstream Parks; Jackson Center; Airstream-friendly Service Centers; Airstreams for Sale by WBCCI Members. I'm sure other contributors can think of other data points that are worthy of being mapped as well.
For that matter, when the survey is put out, there ought to be three possible answers, yes, no, and "I'll decide after I see it (i.e. maybe)."
You can start by putting me down for a resounding "YES!"
WBCCI #1105
TAC LA-4
Old 06-26-2012, 06:18 PM   #80
HowieE's Avatar
Images: 12
The last thing in the world we need is a survey.
The WBCCI has used surveys or a committee to kill ever thing that has ever been suggested.
Build it and they will come. Mark Z. did not take a survey.
2004 Excursion 4x4
HowieE is offline
Closed Thread
greg gibson, vintage-airstream.com
