Closed Thread
Old 12-21-2009, 05:34 PM   #183
Ben4762's Avatar
1989 32' Excella
Lawrenceville , Georgia
Originally Posted by silverleeper View Post
If is that simple why didn't PeeWee list all the people that posted to this thread that are not listed in the WBCCI 2009 directory?
I personally find it hard to speak for anyone. You never really know what point they are trying make. All you can do is speculate. Maybe PeeWee should speak for himself.
I only know what he posted and you are the one that's speculating.
Ben4762 is offline
Old 12-21-2009, 05:36 PM   #184
Baltimore , Maryland
p. 214
Schumann #3090
Schurr #8907
Schwab #3090
Schwartz #6727
Schwartz#6169
Schwartz....
p.239
Yee #4118
Yensan# 7183
Yerk #287....
Frank's Trailer Works is offline
Old 12-21-2009, 05:52 PM   #185
VIKING's Avatar
Boulder Creek , California
28 viewers, and no positive comments?
Is it time to flush this toilet, or what?
VIKING is offline
Old 12-21-2009, 06:08 PM   #186
HowieE's Avatar
Princeton , New Jersey
Images: 12
Can you explane your numbers?
I see 189 posts and 10.039 viewings. Flushing the toilet may be a bit early doesn't look like the paperwork is done yet.
2004 Excursion 4x4
HowieE is offline
Old 12-21-2009, 06:37 PM   #187
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Originally Posted by PeeWee View Post
I am always curious when people make comments about the Club. Do they belong? Are they just non-Airstream bystanders? Are they Airstream owners?
Gene Crawford isn't currently listed in the Directory.
PeeWee... I am sure that your response is obviously in response to the earlier post about you neither owning a trailer, nor being a dues-paying member, and yet still being a club member, and I can understand your indignation at that remark.
However, I'm calling you out on this thread. In your "Charter Member Opinion" thread, I responded as a long-time Airstream owner, and former Club member in this post:
http://www.airforums.com/forums/f286...tml#post767199
You chose not to respond in that thread again at all, and yet here you are in this thread stirring the pot again. The problems with the club are so obvious, they're practically prima facie. You admitted yourself in that thread that nothing's changed in the club in the fifty years since your mother started it. It's unfortunate that you're having difficulty grasping that the Club you have such affection for and are so quick to defend will die from lack of membership with the direction of it's current leadership whether or not they're right or wrong. The club's direction is not a direction that current owners are comfortable taking.
I also find your swift dismissal of the Forums here as fluff pretty interesting since many of our active members here are also active Club members; many of them have been movers and shakers in the WBCCI in the past several years... backbone of the organization kind of people. The overlap is substantial. The Forums here are neither a moving force, nor a negative force. They are merely a place for like minded folk to discuss what's on their mind, and as you can see, those discussions are taking place.
Your contributions here to the known history of Airstream ownership have been greatly appreciated. If you want the Club about which you are so passionate to survive, I suggest to you that rather than merely sparring with the dissidents, and then threatening to cut and run after the first of the year, that the Club might be better served by you carrying the message to the governing body that perhaps it's time for some change for the good of the organization. Take the opportunity to be part of the solution rather than part of the problem.
Thanks for taking the time to hear me out.
Roger
85MH325 is offline
Old 12-21-2009, 06:38 PM   #188
VIKING's Avatar
In response to HowieE:
It was the number of viewers looking at this thread at the time of my last post. My comment is in regards to the last page or two of this thread being mostly pi$$ & vinegar.
VIKING is offline
Old 12-21-2009, 06:52 PM   #189
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
Nor Past Members
Originally Posted by Silverwanabe View Post
IMHO,
if forum members make comments (especially critical) about the WBCCI , you would think or assume that they are current or former members?
Otherwise the comments made do not have that much validity.
Right??
When you throw the towel in you give up the right to continue to wack at the WBCCI. If you want to hang around then have at it.
When you bail do it with grace.
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Ed Emerick is offline
Old 12-21-2009, 07:13 PM   #190
Images: 59
Who made up that rule?
markdoane is offline
Old 12-21-2009, 07:26 PM   #191
Lothlorian's Avatar
Loganville , Georgia
What is the Name of this Forum? The Airstream Knowledge Sharing Forums. What a great concept. Lots of knowledge has been shared about Airstreams on this forum. I never knew there was a club associated with Airstreams until I started to do an inquiry on how to fix my trailer.
I like to read everything that is posted. I guess I should stay away from this continuous conflict, which has been posted under different thread titles. The only comments I have made have been about my life long experiences with clubs (35 years). Many of the same behaviors repeat themselves over and over within clubs even though they can be different activities. I see the same type of arguments with this club that I have experienced in my life time with other types of clubs.
It is like when a company hires a CEO to take over a business they have never worked for selling or building a product totally different from anything they have worked with before. These types of things have patterns that are universal.
If my making a comment has bothered anybody I apologize. Constant fighting is never going to solve anything for anybody. You can talk and talk and talk, but for the last couple of years I've been associated with this forum the same conflict keeps creeping in.
Start a new club and be done with it, go solo, or be happy with the current club. If you are going to air this stuff it is fair game for people to make comments even if they are not members of the club. They are members of this forum.
For all the years I have been involved with clubs it does not matter if the leadership changes. You will always have members who are going to pick the club apart. It is the nature of the beast.
Brian
Brian & Adrienne
Lothlorian is offline
Old 12-21-2009, 07:31 PM   #192
rideair's Avatar
In search to cure the hunger and find perfect nutrition, they began to eat their own.
Paul Waddell
rideair is offline
Old 12-21-2009, 07:36 PM   #193
gklabs's Avatar
1989 35' Land Yacht
Sherburne , New York
I am so glad this topic has come up. I am new to the road of Airstreaming! I have been trying to figure out what clubs and groups to join and not join. I operate a dairy farm with my family here in Upstate NY. So I don't get much time away. I just bought a airstream this past fall, its a fixer upper, but most are. But anyways, when I go camping its about being with my family and friends. I don't care who's in the site next to me, it can be a tent or a diesel pusher, we are all there to CAMP. Everyone has a different opinion on what camping is. Camping to me is having a great time with my family. It sounds to me that these clubs charge you $55 or $75 per year to be part of a over rated registry of owners, where politics have taken over, and you get little in return. Plus I think that my family might be a little too young for most of the units out there. I have looked at a few and it seems like they are not very family/child oriented. Hell it kills me to think I have to pay over $100 per year just to run the trailer down the road, lol.... So I guess I will be the one of many going down the road this summer with no numbers, but don't let that fool you, cause it will always have the name "Airstream" on the side of it, and my sign will always say "Welcome"
gklabs is offline
Old 12-21-2009, 07:58 PM   #194
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
gklabs
Keep an eye on the rally calendar and threads, the forum rallies (these are not the same as WBCCI rallies) are probably right down your line. Also, WBCCI rallies vary widely from unit to unit (they are kind of like a box of chocolates) and can be a hoot. The thing about the WBCCI is you have to be able to accept that it is, to say the least, it has its flaws.....
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline
Old 12-21-2009, 08:01 PM   #195
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I've had fun with this group. Tin Can Tourists
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline
Old 12-21-2009, 08:20 PM   #196
1989 34.5' Airstream 345
Silverton , Colorado
Four Corners Unit likes to camp, eat, drink, socialize, and behave poorly in large groups around the campfire...we also seem to like cheap or free...desert is also good...weight watchers will never be part of our master plan...oh, wait, we have to have one first!!!
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline
Closed Thread
greg gibson, vintage-airstream.com
Satellite TV/Good bye sour grapes Lumatic Computers, Internet & Satellite 33 04-16-2009 12:27 PM
with a screach and burning rubber, it's bye bye belt !!! kepko Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2008 02:34 PM
Good-Bye To My Best Friend Chaplain Kent The Pet Forum 39 12-28-2005 05:14 PM
Good bye and thanks Ronnie..... Silvertwinkie Off Topic Forum 8 06-06-2004 05:46 PM
Bye bye Miss American Pie Rog0525 Our Community 4 04-13-2003 10:18 PM
