Old 07-18-2017, 06:53 PM   #1
2015 16' Sport
Minneapolis , MN
Bought used AS, can I keep/use the existing numbers?
OK, we just bought a 2015 Bambi Sport 16 from a private party, and the numbers on the unit (13920) are applied straight and look good. I don't want to risk taking those off and trying to apply new ones if I were to join the WBCCI.
Can I keep those numbers as my own, i.e. have those numbers transferred from previous owners to me? Thanks all!
augopher is offline   Reply With Quote
Old 07-18-2017, 09:16 PM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
You can have those numbers transferred if the previous owner has not reused them on his new trailer. If they are used you could get a number that is close such as 13928. Also it is your trailer so you can leave the number on even if you don't join the WBCCI
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 07-20-2017, 07:05 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The numbers go with the club membership. So you might be able to get them if the previous owner gave up his membership. Otherwise when you join you will have to accept a different number. I expect you can contact the staff at headquarters and find out the status of the numbers in question.
Old 07-23-2017, 12:57 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
True. But doing so could cause some confusion if a current WBCCI member has the same number on another trailer. But the current member will be the one bothered by it, when people he knows call him up and say, "Didn't I just see you at X campground?" (where you were) when he was actually clear across the country in his new trailer.
Old 07-23-2017, 02:20 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Just call Headquarters and go from there.
I requested my uncles several years after he passed. If a number is not used you can request it.
2004 Excursion 4x4
Old 07-23-2017, 05:37 PM   #6
2015 16' Sport
Minneapolis , MN
Thanks all for the tips!
Listing the numbers of existing 1948 airstream Liners pierrew 1947-1949 Liner 4 08-07-2017 04:10 PM
Wow, we just bought 2 Airstreams. Which to keep?? '74 Argosy vs. '67 Overlander bjmckernan Airstream Lifestyle 17 11-09-2015 11:03 PM
Wardrobe Doors - To Keep or Not To Keep? Rhino33 General Interior Topics 2 10-07-2015 03:34 PM
