Old 06-07-2016, 11:50 AM   #15
FCStreamer's Avatar
2014 30' Flying Cloud
Originally Posted by martin300662 View Post
Squier do two versions of the numbers. The first is on a cling sheet and they describe as removable (actually they say should be removed) or a single sheet with the numbers mounted on a transfer mask. The second is the one to get. You attach the mask then peel it off and it just leaves the numbers 'permanently' attached and ready aligned......for $2 per number plus s/h.
Thanks! I will email them then to see if they can send me my numbers.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 06-07-2016, 11:54 AM   #16
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Wish I had known that earlier! 😕
Good to know though! Much easier and more precise.
Old 06-07-2016, 12:11 PM   #17
1996 25' Excella
Tillsonburg , Ontario
One word of caution when preparing to install the numbers.
Do not get the backing wet before you are ready to peel the number off the backing. I dribbled water on one of my numbers and it would not peel off cleanly
JCW
JCWDCW is offline   Reply With Quote
Old 06-07-2016, 01:10 PM   #18
FCStreamer's Avatar
Got an email reply right away. $2 per digit. $16 in my case, plust $6.95 Priority Mail shipping. Easy as pie.
Old 06-07-2016, 02:19 PM   #19
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Steve,
Thanks. I just ordered cling sheet type and plan to use only at Rallies etc. The window is where I'm going to put them. Squiers even said not to leave them in place permanently due to the concerns of dirt and stuff getting behind against the skin.
DoublTrouble is offline   Reply With Quote
Old 06-07-2016, 03:15 PM   #20
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Put the numbers WBCCI sent you on a piece of plexiglass or a piece of wood or sign board and put them in your front window or on the ground or on a post at your campsite when attending rallies.
I stood on the tailgate of the truck to apply my numbers on the front and used a step ladder in the carport to apply the numbers to the back.
I sketched pencil marks/outlines where the letters go to line them up.
The 1's were real easy and the 8's were a real challenge.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-07-2016, 03:25 PM   #21
FCStreamer's Avatar
I would much rather see them where they belong on the AS skin. Even in their current condition, they look good. From a distance. Don't get too close or you will notice they are not aligned and all the creases from the 17 times we stuck them and unstuck them to get them straight (yet we still failed). I am not concerned about sticking numbers on my AS. Those numbers will be there forever. If they fade, I will remove them and put new ones on.
My biggest gripe is that in the 21st century there are simple ways to get these numbers printed on paper backing to make installation easier. If I ordered replacements I am paying for them, so why not charge whatever it costs to have them that way? Why continue to sell individual digits in a very flimsy 3M film?
Things that make you go hmmmmmmm....
Old 06-07-2016, 03:33 PM   #22
Safari Streamer's Avatar
2015 28' Flying Cloud
Ladson , South Carolina
red numbers.
Many put the numbers on plexiglass but that is not the real Airstream way. It works well for rallies but not for driving down the road and seeing another member of WBCCI. Also, by having them mounted, it just might prevent your AS from being stolen as it is easier to identify.
We had ours made by a "sign guy" on 1 sheet. They are 6" high, 4" wide and 2" thick. Digits are 1" apart.
Kathy Narowski
#2555
SC Coastal Unit
TAC-SC5
Safari Streamer is offline   Reply With Quote
Old 06-07-2016, 05:11 PM   #23
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
WBCCI......are you there? What size and font?
banderabob is offline   Reply With Quote
Old 06-07-2016, 05:54 PM   #24
m.hony's Avatar
2013 30' Classic
Oh...
The dreaded 8...
TAC #MS-10
Airforums #70955
Old 06-07-2016, 05:58 PM   #25
m.hony's Avatar
2013 30' Classic
It would help if all 4 numbers were together on one backing.
Surely applying 1 thing straight and true is easier than aligning and applying 4, 5, or 6 things.
Maybe take the current numbers or trailer to a sign, decal, or print shop so they'll have the size, don't, and color to make new ones from- on a single piece of backing-
Maybe have a pro install them-
TAC #MS-10
Airforums #70955
Old 06-07-2016, 07:28 PM   #26
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I only found out when I wrote to Rita Squier and asked Steve!
martin300662 is online now   Reply With Quote
Old 06-07-2016, 10:38 PM   #27
Twinke58's Avatar
1958 26' Overlander
Kansas City , Missouri
I did mine just like WBCCI said to place them. If you need new ones they cost $10 bucks for a set.Click image for larger version
Name:	ImageUploadedByAirstream Forums1465357022.583247.jpg
ID:	264017Click image for larger version
Name:	ImageUploadedByAirstream Forums1465357045.531899.jpg
ID:	264018Click image for larger version
Name:	ImageUploadedByAirstream Forums1465357093.348458.jpg
ID:	264019Click image for larger version
Name:	ImageUploadedByAirstream Forums1465357121.047224.jpg
Sent from my iPhone using Airstream Forum
Twinke58 is offline   Reply With Quote
Old 06-08-2016, 07:15 AM   #28
1996 25' Excella
Originally Posted by m.hony View Post
Oh...The dreaded 8...
I found the 4 was the worst, but I don't have 8's
I mounted mine in the window in the rear and on the plastic stone-guard in front. Glass is easy....plastic was a challenge.
We have lots of members in our unit that put up the numbers only at the rally or campground. I would rather know the AS I see on the road is actually a member, rather than just assuming it is a "baldy"
JCW
Big Red Numbers Simon WBCCI Forum 32 03-24-2014 01:30 PM
Big Red Numbers SL4BLLT On The Road... 2 05-28-2012 05:37 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 02:18 PM
Big Red Numbers Sasquatch WBCCI Forum 100 08-06-2008 08:25 AM
