Old 08-01-2003, 07:47 AM   #43
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Static cling followup
Jack,
Was it just normal wind that lifted the static cling or highway driving? Also, do you know if the surface underneath was cleaned well before applying?
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 08-01-2003, 01:51 PM   #44
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The person told me that she got to a rally, wiped down the front of the trailer and stuck it on. Apparently it came off when the wind came up that night and she found it on the ground. Upon subsequent inspection she found that the point of failure was the corners. Once one lifted slightly, the breeze provided the necessary lift to start the peel back.
She did not drive with them on.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-01-2003, 03:07 PM   #45
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Maybe rounded corners?
Jack,
That does make sense as a pointed corner will be focus for any stresses that would lead to a lifting. I wonder if going with very rounded corners might prevent the lifting. Guess I will just have to have a set made and see.
Thanks for the info
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
Old 08-01-2003, 04:15 PM   #46
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
So be it
I put my number on, using high-grade numbers from a sign maker, as soon as I had my WBCCI number. My trailer name is by the door using the same grade of lettering. I dam careful at the carwash, but everything has stayed on as intended.
As far as worrying about ghosting the finish, that will be the worry for someone on down the line since the number and name will stay there so long as I own the trailer.
John W. Irwin
WBCCI #9632
Old 11-03-2003, 08:24 PM   #47
Those red numbers
I would think that one could have the numerals printed on a waterproof type paper and then stick to paper onto those flat magnets that you see on frig doors. I got one with a paper covering that allowed me to stick a photo onto the back of the magnet and can plaster it anyway on a vehicle. Oops...I just thought of a flaw in my plan - the A/S would have to be one of the new steel ones or the magnet won't stick! Dang. Back to the drawing board.
jw
smallfry is offline   Reply With Quote
Old 11-03-2003, 10:48 PM   #48
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Gee .. maybe we could just pop rivet the numbers on.
Porky
TrailerGypsies.com
WBCCI #3405 Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 11-04-2003, 04:21 PM   #49
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I took off my numbers last weekend, along with the old WBCCI sticker from the PO.
The numbers came right off, with the help of a heat gun. The ahesive residue also came off, with a bit of 3M adhesive remover. Of course there are ghost numbers now, but still much less noticeable than the faded red numbers that were there before.
The WBCCI stickers were another story. They came off in microscopic fractions, and left a thick glue residue that was a real mess to remove. The glue left an impression of the sticker, like a ghost, on the clear coat. I can still read the letters and see Wally's mugshot on the aluminum. I think UV light does a lot of bad things to plastic. i will not put any more stickers on the Airstream. It looks much better without the numbers, in my opinion. Besides, I am not a member, not planning to become one.
Uwe
www.area63productions.com
Old 11-04-2003, 04:47 PM   #50
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Geez, all this over a bunch of red numbers Look on the bright side You could have the situation I have; apparently my AS has had at least 3-4 PO's, everyone had a different number, or the same guy joined and had 4 different numbers, all of the ghost numbers are still visible as well as some of the actual numbers, black as well as red. And some well meaning? person tried to cover them up by spraying some of them with silver spray paint Now I don't have any choice but to strip the clear coat. LOL I just hope the paint will strip.
Aaron
Old 11-05-2003, 01:37 AM   #51
That's nothing! A previous owner of my trailer had them sanded off with 40 grit sandpaper and then stuck new ones on upside down! Then the next owner had them sand-blasted off and his new ones stuck on with crazy glue! Finally, the last owner had no choice but to cut them out with tin snips! jk
bbb
biggerbadbrad is offline   Reply With Quote
Old 11-05-2003, 06:28 AM   #52
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Mounting the WBCCI numbers
Hi, all...
For those of us who, like me, have PO number "ghosts" to cover, and are too lazy to use anything but our WBCCI provided numbers, they are actually quite easy to install despite the cryptic instructions provided with them.
The vinyl numbers used for the last ten years or so peel off fairly easily when they're warm.
First, pick a cool day in a shaded area if you can. This is much easier if the trailer skin is cool and shaded.
Take a piece of masking tape and run it across the bottom of the area where the letters are to be placed. That will ensure that your numbers are all level. If you want to check spacing, you can put a piece of masking tape above where each number should go. You can adjust the piece of tape until you're satisfied with the spacing.
Mix a dishwashing detergent/water mix in a hand spray bottle. Spray the area of the first number liberally with your soap/water mixture. Peel the first number from the backing, and slide it onto the wet area. Move it around where you want it to go, as it will slide easily on the soap/water mixture. When you have it in place, gently blot/squeegee the number down with a towel or rag, making sure that all of the air/water bubbles are out.
Move on to the next number. When you're done, remove the masking tape. That's all there is to it!
Roger
Old 11-05-2003, 07:46 AM   #53
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Same situation as Uwe, here, although I had a hard time getting the numbers off, as well as the glue residue. Andy's wet rag/steam iron did the trick, although some cussing was still required to get off the old wally-sticker. But I, too, have wally's mug burned into my clear-coat. the detail is amazing, really. I wonder if its the color, or perhaps chemical makeup of the inks on the sticker?? the glue should be the same throughout, wouldn't you think?
Best solution is probably to just cover the spot w/ a new sticker. My clear coat looks too good to go to the trouble of polishing. (I'm thinking that the trailer must have spent a good deal of its life parked indoors, or something...). Anyway, I need to call the wbcci and get my number changed to "88888". that's the only thing that'll cover over the ghosts of multiple old numbers....
Chuck is online now   Reply With Quote
Old 11-05-2003, 07:51 AM   #54
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
DON"T YOU DARE! That's the number I HAVE TO HAVE Someone already tried it on my unit but I don't think the 8's will cover up 1's and 7's to well
Aaron
Old 11-05-2003, 09:37 AM   #55
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
What was that number again that they used for the Enterprise on TV? NC... something..... Tempting..
Uwe
Old 11-05-2003, 10:11 AM   #56
85MH325's Avatar
Tipton , Iowa
Images: 37
U.S.S. Enterprise NCC 1701A-D
Sorry... it's already taken... I checked the WBCCI book a few weeks ago!
Roger
BIG RED #'s Chris Deeley WBCCI Forum 3 11-09-2003 05:10 PM
red numbers lido&linda 85/345 Airstream Motorhome Forums 1 09-05-2003 10:39 AM
I need numbers, Part numbers that is. thenewkid64 Airstream Motorhome Forums 1 07-19-2003 10:51 AM
WBCCI Numbers on Argosy overlander64 Our Community 2 06-26-2003 04:21 PM
WBCCI Numbers question? tiniree WBCCI Forum 2 04-22-2003 12:43 PM
