08-06-2017, 07:11 AM
2009 25' FB International
2018 27' Globetrotter
Tavares
Big Red Numbers
We decided to join WBCCI and yesterday I received our big red numbers, the ones I chose, 22721. I chose these numbers to honor my father who was born July 22, 1921. I owe my love of traveling to him!
Now to place them. I've read the instructions and they seem fairly easy to understand. But just curious if there are any tips from those who have already done this?
Thanks!
08-06-2017, 09:01 AM
2012 27' Flying Cloud
W
, New England
Big Red Numbers
I can't help with the placement (had it done at the factory - long story). Just wanted to comment on how awesome it is that you got those specific numbers for that particular reason. Great story!
08-06-2017, 09:28 AM
Biloxi
, Mississippi
Keep a spray bottle of soapy water handy. Spray the area down, apply numbers and adjust to that perfect position. Use a squeegee or credit card to remove any bubbles.
MICHAEL
08-06-2017, 01:41 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
Mix a tablespoon or so of dish soap in a small squirt bottle.
Mark a straight line for the bottom of the numbers.
I used blue painters tap to hold the numbers in place and make a few small marks with a grease pencil to guide where I wanted to place them.
One number at a time, use LOTS of spray soap/water and place the number.
If you keep it all wet enough, you can slide the numbers around until you like the positions. You can peel the numbers back and re-wet them a time or two to keep things sliding.
Use a small squeegee to work the bubbles out. Be careful, they will slide some if you work to hard.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
08-06-2017, 05:41 PM
1971 27' Overlander
2023 28' Flying Cloud
Monmouth
, Oregon
Affirming the lots of soapy water.
Adding, don't tackle it in the wind. Or like me, don't start in the afternoon right before the clockwork offshore breeze picks up.
“Let’s be careful out there.”
08-06-2017, 08:00 PM
2020 30’ Globetrotter
Ramara
, Ontario
Big Red Numbers
I did my numbers this afternoon. They do tend to slide around a little too easily with the application of lots of soapy spray. Worked the bubbles out with a gentle swipe of my finger and then waited an hour for them to dry in the sun so I could clean up the soap residue.
9194 were the years of our sons birth. Seemed to be an easy number to remember.
Do many folks use the wbcci club emblems? I did not have room on the rear but am thinking of putting one above the front numbers. Not sure I will like the look of it there though.
Kevin
08-06-2017, 08:13 PM
Tavares
Attachment 291509
Kevin
The numbers look great! Plus they have a special meaning. I haven't decided about the club emblems yet. I plan on tackling the project tomorrow.
I see you are located in Ontario so you are also in Region 2. Correct? If so maybe I'll see you at a rally at some point in time.
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
08-06-2017, 08:16 PM
Tavares
Yes I was so happy (and surprised) that this particular set of numbers was available. And thanks for your comments. My dear father is gone now but in a way he will still be traveling with us! He would love it!
BRN 22721
08-06-2017, 08:19 PM
Tavares
Thanks to all for the suggestions. I remember working with shelf liner paper that was sticky and I had that stick to everything except what I wanted it to stick to. So being aware of wind is great advice.
Again, thanks!
BRN 22721
08-07-2017, 10:40 PM
Walnut Creek
Worried about it for a year. Finally defined it was time. Cleaned the area carefully. Set a line of blue painter's tape across the bottom edge of the space where the numbers go. Referenced the Airstream logo as a guide. Marked the center and established the space for each number - they are different width. Then carefully placed each one. No soap, but much care and no wind.
Not all numbers are created equal as to ease of install. Twos are going to be a challenge, so use the soap. The 1 is a snap and the 7 is not too bad. Hint - get some boat numbers from the hardware store and practice. They are smaller and a bit stiffer, so do not get over confident.
If it all goes sideways - the sign shop can make you some new ones on a sheet that is spaced correctly. (they do installs too )
Good luck - Pat
PS - it really isn't that hard - take your time and make it so.
08-10-2017, 10:36 AM
2010 27' FB Classic
2003 36' Land Yacht XC Diesel 330 hp w/2slides
Shelby
, North Carolina
Why doesn't WBCCI supply the numbers on a transparent sheet? It would make installation a lot simpler.
08-10-2017, 10:48 AM
2007 22' International CCD
Corona
Probably because it's much cheaper to stock only 10 individual numbers instead of hundreds of custom ones....
08-11-2017, 04:24 AM
Ramara
, Ontario
Easier to mail too. [emoji41]
08-12-2017, 05:16 AM
Biloxi
, Mississippi
How much would you be willing to pay? Additional cost would have to be added to an already high membership fee. You can easily have a local print shop make them up. I know some have done that with very good results.
MICHAEL
08-12-2017, 01:29 PM
Walnut Creek
There is another idea. You can have your numbers made to a smaller size by a sign shop and apply them to your bumper and LPG cover. Still quite visible to find you in an emergency, will not leave a ghost image, and make you different from the crowd so they will talk about you at events. Pat
08-12-2017, 03:43 PM
1987 25' Sovereign
Fort Collins
Easy to get what you want ordering online. And you can be unique!
Alumacoot
“We are confronted with insurmountable opportunities.”
08-13-2017, 07:34 AM
2010 25' FB Flying Cloud
Davenport
, Iowa
I just read an article on caravans. Of the first 7 A$, 6 did NOT have the "big red " numbers displayed.
I was able to get the same numbers for both WBCCI and Air Forum. Instead of having 2 sets of numbers, I went to the local sign shop and had the numbers made from "Old Glory" stock. The numbers are on one piece of vinyl.
mj
08-13-2017, 09:01 AM
Tavares
Numbers Placed
It seemed as though when I had time to install the numbers we had a chance of thunderstorms which I thought would not be good. I would have hated to see them washed away before they dry!
After several rearrangements and the blessing of my DW they are now in place. The spacing is a bit tricky. One would think that they should be evenly spaced but that just didn't look "right" when I had them laid out that way.
I placed the WBAC sticker on the window. Just made more sense to me.
Thanks for everyone's suggestions.
09-17-2017, 05:14 PM
2005 25' International CCD
Fleetwood
, North Carolina
Those look great Hans627. Nice spacing. I've moved the new round WBAC decal to the side instead of on top so it can be seen easier. I like it there, like on your window.
09-17-2017, 06:21 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We left the round WBCCI emblem off of the Classic. We only installed the numbers when we went to the International event in 20
We also put the numbers on two plexiglas sheets that have removable suction cups for the 23D. We store the two plexiglas sheets under the mattress and the suction cups in a bag.
