Go Back   Airstream Forums > Airstream Community Forums > Clubs, Organizations & Associations > WBCCI Forum
Old 02-05-2014, 06:14 AM   #41
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Originally Posted by damonbeals View Post
You could join the WBCCI and request those numbers!!! No messy removed required.
But if you do want to remove them, a hair dryer or heat gun, plastic putty knife, will get them off, follow up with some goo-gone or WD-40.
Damon
#4827
Damon,
Good recruiting effort. I have enjoyed the club for 4 years and counting. As well as Airforums, all great people!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 02-05-2014, 08:15 AM   #42
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
Squier Design Numbers
I am curious about these numbers. How do they stay on? Do you take them off when traveling and put them back on when you get to your destination? Would rain or the wind cause them to come off?
Sounds like an easy solution.
Rick
rperrym is offline   Reply With Quote
Old 02-05-2014, 08:23 AM   #43
Mantua , Ohio
The club numbers from WBCCI are permanent or close to it. If you buy a new trailer you can get a new set of numbers. They will not blow off and are not affected by water. That is why you can still read them on 50 year old trailers. Jim
Old 02-05-2014, 10:52 AM   #44
daveswenson's Avatar
2012 28' International
Olympia , Washington
Rick
The Squier numbers are on a vinyl sheet. You clean and dampen the surface, place them and squeegee out the bubbles. I guess it's static or surface tension that keeps it on. They've stayed in place through wind, rain and several washings. These are the same things that are used on race cars, so driving with them on is not an issue. If you're looking for easy, this is it.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 02-05-2014, 12:30 PM   #45
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
^- x2!
Old 02-05-2014, 01:51 PM   #46
rperrym's Avatar
Thanks for the information. Sounds good to us.
Rick
Old 02-19-2014, 06:16 AM   #47
1969 21' Globetrotter
Foley , Alabama
Any Advice on replacing WBCCC No's
Thanks everyone for the information, I purchased a plastic spatula from Lowe's and as soon as it gets warm enough, I will take my heat gun and spatula and breeze through this task. P.S. I had attempted to get the original WBCCI No.'s but they was not available. Thanks again everyone.
Mick33 is offline   Reply With Quote
Old 04-23-2014, 04:34 PM   #48
W , New England
Originally Posted by SteveSueMac View Post
^- x2!
I'm quoting myself here to CORRECT myself!
I absolutely DO NOT recommend the vinyl cling sheet numbers any more!!!!
Mine created ugly corrosion!!!!!
Just had Jackson Center install regular ones and try to correct the damage to the skin. Can't be done :-(
It's a love mark now :-)
I'm going to reach out to Squire (a great company no doubt) to let them know they shouldn't recommend this for Airstreams.
If I had just placed them on a window I would have been fine. But this ugly corrosion will forever have to be treated with CorrosionX to keep it from growing any further. It can't be fixed.
I loved the simplicity but the damage absolutely isn't worth it. Please learn from my mistake and just don't do this to your trailer.
Old 04-23-2014, 06:44 PM   #49
reinergirl's Avatar
Hollis , New Hampshire
Ouch that looks nasty!
reinergirl is offline   Reply With Quote
Old 04-23-2014, 07:25 PM   #50
W , New England
Yup. Heartbreaking. And I'm kicking myself. I thought about just putting it on the windows. Ugh. It's really ugly. BUT - its not the end of the world. Instill love the trailer :-)
Old 04-24-2014, 10:15 AM   #51
2011 30' Flying Cloud
Arvada , Colorado
Squire is great to deal with, but that said, we too experienced the trailer skin issue in using the static cling numbers. We had to replace a couple of sheets that blew off and eventually they deteriorated anyway. We have since mounted the individual numbers.
Jack46 is offline   Reply With Quote
Old 04-24-2014, 10:45 AM   #52
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Don't know about the cling sheet but I did just install vinyl numbers. Hope no corrosion appears.
TinCan
graysailor is offline   Reply With Quote
Old 07-05-2014, 08:32 AM   #53
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Just the other day, I put my numbers on my new Airstream. I used Squire to make the decal for me and the application was so easy--much easier than trying to put up the individual numbers, and Squire insured that the letter spacing was correct for the font and size. Being able to tape the transfer sheet in place, then get off the ladder and see how it looks made the job very easy.
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
SilverCabin is offline   Reply With Quote
Old 07-05-2014, 02:04 PM   #54
W , New England
Please look just a few replies up. Several of us (myself included) experienced ugly corrosion from the vinyl cling on sheet.
My recommendation - don't do it.
If you HAVE to do it that way, clean the surface before applying, use only for brief trips and take it off between use.
But really - don't do it at all. Get the numbers from WBCCI and use them only.
I emailed Squire about this problem and recommended they let people know before buying. I'm guessing that didn't happen. I've never heard back from them since raising this issue to their attention. They shouldn't sell these to Airstreamers.
The picture below shows the IRREPAIRABLE damage (according to Jackson Center) and the new WBCCI numbers installed.
Old 07-05-2014, 10:38 PM   #55
My Squire numbers have been on for over a year. No signs of corrosion. But my rear numbers fell off somewhere on the highway.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 07-07-2014, 12:54 PM   #56
Viera , Florida
SteveSueMac, I didn't use Squire's vinyl cling or static cling, I used an adhesive decal they made for me. Thus, the numbers are stuck on just like the numbers from WBCCI. The advantage of having Squire build the decal was that all four numbers went on as a unit instead of one at a time.
We've been having a discussion in the Florida Unit about mounting numbers. I'm the newsletter editor and put a link to your post and picture in our May edition, as an example of what not to do.
Randy
Randy & Pat Godfrey
Old 07-07-2014, 04:10 PM   #57
W , New England
Randy
Oh, that may be a better solution. I LOVED the simplicity of the cling sheet and it looked great (for a while). The ability to put all (individual) numbers up in a pre-pattern would be VERY helpful. I don't know the material of the WBCCI supplied numbers compared to the Squire materials but hopefully the Squire version isn't the same as the cling version.
Good luck!!!
Oh - and always glad to serve as an example of what not to do :-) I think most people figure that out early and pretty much do the exact opposite of what I recommend :-)
Old 07-09-2014, 06:45 AM   #58
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I cheated. My Airstream had very distinct ghost numbers. I called the club office and requested the same numbers. They went on easily without all the hassle of trying to line up and space them correctly.
MICHAEL
Old 07-09-2014, 12:43 PM   #59
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I went through all the rigamarole of measuring and drawing lines. The 8 was still very hard to apply.Click image for larger version
Name:	ImageUploadedByAirstream Forums1404931378.598611.jpg
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-09-2014, 12:44 PM   #60
m.hony's Avatar
2013 30' Classic
Maybe I should have requested #1111...
The 1's went on real easy-
TAC #MS-10
Airforums #70955
