Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2004 Safari > Safari slide out models
Old 07-19-2009, 07:33 PM   #1
Profile:  2000 31' Excella
Maryville , Tennessee
Slide out questions.......please.
Hello, looking at a slide out safari model 28ft.
I am concerned about my F250 towing this ? Any problems ?
What is this talk of a new hitch I might need ? Class V or something ?
I have a VERY heavy tow package insert with ball and the shank is solid not hollow........would this do it ?
Is the tow weight very different on these models than a 25 safari ?
Can anyone please give me some info. that I can learn about these models pros and cons please ?
My sincere thanks,
Robbie R.
Robbie R. is offline   Reply With Quote
Old 07-19-2009, 07:52 PM   #2
CA Streamer's Avatar
Profile:  2005 28' Safari S/O
Atascadero , California
Images: 20
Robbie, What year is the trailer? The hitch weight changed around 2003. The older 28' SO's have a heavier hitch weight. The newer ones are rated 1040 lbs, although when I weighed mine it was actually 980 lbs fully loaded. A class IV hitch is rated to 1200 lbs so it is no problem for the newer 28' slides.
Some of the members have gone to a class V hitch, but those are generally ones that have 34' SO's Those are generally rated about 1250 lb hitch weight. If you call Airstream they can give you the hitch weight for the trailer you are thinking about.
As far as towing with the F250, that is no problem. I tow mine with an F250 diesel and it is a great match. Just make sure you have weight distribution bars and anti sway. I use a Hensley hitch and I love it.
I really like my slide out. It gives me a little extra room in the living area. have had no problems after 3 years and only a minor leak when the slide was open during an extremely heavy wind driven rain.
Steve-- "Mongo only pawn in game of life"
CA Streamer is offline   Reply With Quote
Old 07-19-2009, 08:05 PM   #3
Airslide's Avatar
Profile:  2001 30' Limited
Novato , California
Images: 47
Send a message via Yahoo to Airslide
Im using the Reese dual cam. Im very happy with the stability of the trailer with this unit. The tongue weight is very heavy so once you decide on the type of hitch you want get every thing weighed and dial it in. There a tons of threads here that deal with that. Enjoy you S/O. We love ours.
Vinnie
2001 Airstream 30' S/O 70th Anniversary
1994 F-350 Crew 7.3 IDI Turbo, C6, Dually
Airslide is offline   Reply With Quote
Old 07-19-2009, 08:27 PM   #4
Year is 04. Thank you all. I am still working trying to get it home.............
Robbie R.
Slide-out no slide finalcutjoe General Repair Forum 0 10-05-2008 06:38 PM
Slide Out Won't Stream 1529 General Repair Forum 5 05-01-2008 11:41 PM
slide in rock60 Off Topic Forum 14 10-21-2006 09:42 AM
To slide or not to slide Pimprnel Airstream Trailer Forums 4 08-14-2006 01:35 PM
Slide out zamboni Our Community 3 08-08-2002 09:39 AM
