Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2004 International CCD
Old 04-23-2004, 06:02 PM   #1
rseagle's Avatar
Profile:  2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Noisy Refrigerator Vent Fan
OK, let's do some Brainstorming here.
We like to Boondock and enjoy the peace and quiet of our favorite secluded mountain campground in the Summer. I'm afraid, that the noisy refrigerator vent fan in our 22' CCD is going to drown out the natural sounds we travel so far to hear. Our first trailer, an SOB, had a vent stack to the roof with no fan. It was dead quiet so we could hear the stream, Whip-Poor-Wills at dusk, Cicadas, wind through the trees, etc. You get the picture.
I've read of retrofitting the 12v fan with a 24v fan, which rotates at a slower RPM, but twice the Amps. It still makes noise.
I'd thought of fabricating a 4-6' metal or plastic vent stack that could be temporarily attached to the CCD when we get to the campground that would draw out the hot air behind the refrigerator. Is this practical? Could it work like my SOBs stack, so that the fan's thermostat would keep it from coming on?
Any other ideas from you "Out of the Box" thinkers out there?
rseagle is offline   Reply With Quote
Old 04-23-2004, 06:55 PM   #2
mandolindave's Avatar
Profile:
My 1973 20' has an intake vent underneath the fridge and an exhaust vent on the roof. The original fridge had no fan. The new fridge has a fan. The
installer said that I really only needed the fan for hot days. I didn't
want to be running the fan and using up my batts so we are installing
a manual swith to kill the fan when I need too.
It would be nice if you could hear another trailers fan , to see if
you have a funky fan.
mandolindave is offline   Reply With Quote
Old 04-23-2004, 08:24 PM   #3
Turtle's Avatar
Profile:  2004 16' International CCD
Arcata , California
I'm adding a switch to my refrigerator fan on my trailer tomorrow. Our trailer is so small you can't get away from the fan. As I've detailed on another (see thread "noisy refrigerator fan"), I moved our fan to a quieter location which really helped. We really only need to turn it off for sleeping.
Turtle is offline   Reply With Quote
Old 05-03-2004, 12:03 AM   #4
MaShep's Avatar
Profile:
Unhappy
Hey Jamie:
Would be cool if you take a few pics of your project? I'm also wondering, how much noise does your water pump make when you turn on the faucet? Ours is extreemly loud!
Cheers, Linda
MaShep is offline   Reply With Quote
Old 05-03-2004, 08:33 AM   #5
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
The fan runs a lot faster than is needed. One approach is to put another 12v fan in series with the first; both will run slow and without noise. Another option is to put a resistor in series with the existing fan to slow it down.
Do a search ... there are a couple of long threads on the fan noise problem.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 05-03-2004, 09:53 AM   #6
Arr, we captain our ship!
Xray's Avatar
Profile:  Currently Looking...
Santa Fe , New Mexico
Images: 44
Here's my solution for our '04 22' CCD fridge fan noise (quite loud!):
SilenX 120mm 11 dBA Fan $26.00
Part number: 0000375
11dBA is virtually silent.
I ordered it from EastLuna.com. According to my measurements, it should be a direct fit as a replacement for the factory original.
Best regards,
X
Xray is offline   Reply With Quote
Old 05-03-2004, 01:46 PM   #7
luckydc's Avatar
Profile:  Richmond , Virginia
Fan Noise
X
Please let me know how that works out. Had the Bambi out boondocking this weekend. The fan ran contantly, I assume because the gas flame. Eventually, I had to discontent it and turn down the frig so I could sleep.
Very interested in the SilenX. Appropriate name, too!
Paul
WBCCI #2468
2006 Ford F-150 Lariart 4X4
2004 19' Bambi Safari LS
luckydc is offline   Reply With Quote
Old 05-03-2004, 01:55 PM   #8
luckydc's Avatar
Fan Noise...
X:
Couldn't wait. Ordered one. Thanks for the tip.
Paul
WBCCI #2468
Old 05-03-2004, 03:19 PM   #9
rseagle's Avatar
Images: 33
X:
Is this fan for Direct Current (DC) use? What is the amperage draw?
Old 05-03-2004, 03:28 PM   #10
luckydc's Avatar
SilenX
Bob:
From the site:
SilenX fans are the perfect complement to SilenX power supplies in your system! Featuring a noise to airflow ratio no other fan on the market can touch (papst, panaflo and blacknoise don't even come close!), these are the perfect fans for your silent PC. Each SilenX fan comeswith silicone composite fan vibration dampening mounts, no other fan on the market comes packaged with such mounts! 3->4 pin convertor in included with every fan so you have the option of running it off the motherboard of the power supply, this is one amazing deal!
Features:
Fan Swept Forward Fan Blade Design
Smoother, Thinner Fan Blades
Highly Efficient Hypro Bearings
Vibration Isolation Mounts
Specifications:
Fan Dimensions: 120 x 120 x 25mm
Fan Input: 12V/1.2W
Fan Speed: 1400 RPM
Air Flow: 40 CFM
Noise Level: 11 dBA
Three Pin Connector
Four Pin Connector
What is the ampage of the factory fan? Boondocking this weekend didn't even put a dent in my batteries, so not certain I'm concerned about this fan being a big draw. I want quiet!
Paul
WBCCI #2468
Old 05-03-2004, 03:29 PM   #11
dtbw's Avatar
Profile:  1999 34' Limited
2002 19' Bambi
Allen , Texas
Specs
This fan is for use in a PCs where all the fans are DC driven. The manufacturer's website specs this fan at 12V/1.2w so that mean 100ma of current. I have order a pair of these. I previously replace the factory unit with a lower rpm, high volume unit (a big improvment), but I think I can still improve it more with these fans. My hope is that with 2 running in series, I can virtually eliminate the refrig fan noise while still providing a good flow of air thru the refrig condensor.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 05-03-2004, 03:51 PM   #12
rseagle's Avatar
Images: 33
The Silenx fan looks like a good solution! Might have to give it a whirl. Sorry about the Pun!
I pose another idea: Could a rheostat (variable resistor) be used with the existing fan to slow the RPMs to a quieter speed? It might be a cheaper alternative then 1 or 2 Silenx fans $26 ea)?
Old 05-03-2004, 04:14 PM   #13
dtbw's Avatar
2002 19' Bambi
Allen , Texas
Problem is the with the fan blade design
The factory fan is a plain vanilla design. The blades are not designed for quiet operation or large volumes of airflow. Slowing it down will cut some of the noise, but it cut the flow of air faster than the reduction in noise. You need a better blade design. As I mentioned, I already replace my factory fan with a lower rpm, high volume design, which made it much quieter inside, but outside sitting under the awning, it was still a nuisance. The key is lots of slower moving, high efficiency blades designed for quiet running. Putting two of these in series may still not result in quite as much airflow as a single unit running at full speed, but the air will be distributed over a greater area, so the result should be satisfactory cooling.
david
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
WBCCI # 7548
Old 05-03-2004, 05:27 PM   #14
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Yes, but at the cost of loss of power. depending on the type of variable resistor or Potentiometer you use the loss in voltage is normally done by a resistor that generates more heat. So you get 70% efficiency to be quite but still have the same draw or load on the batteries. If you are boondocking it can make a difference. It will be a lower cost alternative, but as mentioned in other posts you reduce the airflow. The reduction in airflow can make the refer work harder to keep the food cold. I guess what I am trying to say is TANSTAAFL. You are going to have a cost somewhere. So I would go with 2 in series or the quieter fans IMHO.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
noisy refrigerator fan Turtle 1999 - 2004 Bambi 9 06-03-2004 04:45 PM
Furnace Fan qbee Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-30-2004 06:41 PM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 07:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 06:35 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 11:44 PM
