Old 11-19-2002, 01:24 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Washing/waxing "new" clearcoat
I have been advised that the service manager (Airstream dealer shall remain nameless ) that they DO NOT suggest using Walbernize on my 2002 Classic.....
Having gone to a local parts store and buying what I hope is a very mild soap that protects clearcoat finish, I am wondering if that is ok...
What shall I wax with?
What shall I wax/polish with?
All I can say this "new" clearcoat is a real problem apparently.
Kistler
Kistler is offline   Reply With Quote
Old 11-19-2002, 01:48 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up IMHO
Kistler
Since your unit is so new, I'd really stay away from any soap, however mild..Plse take a look at this product..
Here's the link.
http://www.walbernize.com/permaguard.html
I've not heard of ANYONE who has used this company's product to have had any problems with it. Not sure why your contact was against using this but..Maybe there was a slight miscommincation as to what was your requirements??
ciao
53flyingcloud is offline   Reply With Quote
Old 11-19-2002, 02:35 PM   #3
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
Whoops
I mistakenly erased your message, but I remembered your name, so I'll answer here.
I haven't chosen a wax yet. The unit is coming up to the 6 month mark and it is getting cool enough here to wax it without having shade,so I'll have to make a decicsion soon.
I expect that I will just use the RV wash I have been using so far and look for an easy to apply wax. Probably a soft wax since it is such a big expanse to apply.
John W. Irwin
WBCCI #9632
Old 11-19-2002, 02:41 PM   #4
Contributing Member
Pahaska's Avatar
Clear coat? No.
Just reread your inquiry. The current models do not use a clear coat. The aluminum comes from Alcoa with a painted finish that is essentially the same as a finish on a car.
My manual says to just treat it like a car finish and that's what I intend to do. I have washed it every 2 months with sthe same RV wash I used on my previous trailers.
John W. Irwin
WBCCI #9632
Old 11-19-2002, 03:17 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
john
i think he said he has a classic, don't they have "regular" aluminum skin?
john
Old 11-19-2002, 03:24 PM   #6
Contributing Member
Pahaska's Avatar
Skin
It is my impression that all of the A/S trailers for the last few years have had the precoated Alcoa aluminum. It should be spelled out in his manual. Clearcoat went out some time ago.
Unfortunately, my manual is in the trailer at the storage yard and I can't quote directly from it at the moment. The manual simply says to treat it like a car finish, though.
John W. Irwin
WBCCI #9632
Old 11-19-2002, 03:30 PM   #7
1984 29' Sovereign
Savannah , Missouri
Question He says she said
this is what I understood...
ciao
Old 11-19-2002, 03:45 PM   #8
Contributing Member
Pahaska's Avatar
Clearcoat
There is no "new" clearcoat.
Clearcoat, in the A/S world was a clear acrylic finish applied over bare aluminum after the trailer was built. When it peeled off, usually in patches, the unprotected aluminum oxidized. Clearcoat hasn't been used for several years. At the rally this last weekend, I saw quite a few peeling, clearcoated trailers.
The current trailers are prepainted. According to the manual, the finish is the same as is applied to autos, except that it is applied to the aluminum at Alcoa instead of being applied on the trailer.
I don't know of anyone who has had finish problems with the recent trailers. I intend to follow the instructions in the manual and treat my trailer just like I treat my car and truck.
Kistler should have the same pages in his/her manual that I have in mine.
John W. Irwin
WBCCI #9632
Old 11-19-2002, 03:52 PM   #9
Contributing Member
Pahaska's Avatar
And I might add ...
The dealer was probably right to recommend that Walbernize not be used. Walbernize is probably loaded with plasticizers to keep the old acrylic clearcoat from deteriorating. Plasticizers are probably the wrong thing to put on the finish on the current trailers.
John W. Irwin
WBCCI #9632
Old 11-19-2002, 06:03 PM   #10
Kistler's Avatar
2002 25' Classic
I know you wrote something to me about clearcoat BUT how do I access your reply?
Kistler
Old 11-19-2002, 06:06 PM   #11
Kistler's Avatar
2002 25' Classic
OK you guys....found your replies....thank you for the clarification.
I really don't know what I would do without you.
Kistler
Old 11-19-2002, 07:50 PM   #12
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
From the Source.....
This was part of an article on upkeep from the Blue Beret, June 2002. The article was called Schu's News. Here is a Link to the full article.
“This and That “
Plasticote- is a clear acrylic coating used to protect the aluminum skin from oxidizing.
This was used prior to 1999 models or on units that are stripped and recoated.
This can be maintained by washing trailer and then using Walbernize Super Seal and Glaze.
Starting in 1999 trailers were built with metal that was coated with PF8A0-1 Flourocarbon Clear paint. This finish is applied by Alcoa before Airstream receives the metal used to build the trailers.
This finish is durable and can be easily maintained by washing with a 5% solution of any common detergent and then waxing. Walbernize products work well for this.
Never use harsh solvents on either of these finishes.
Hope this helps
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 11-19-2002, 07:58 PM   #13
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
And that is the aluminum you are seeing covered by the PF8A0-1 Flourocarbon Clear. Not a painted gray surface
This quote was taken from the Airstream web page.
"How do I clean the aluminum exterior of my Airstream?
For units with clear-coated aluminum we recommend washing the exterior about very 4 weeks or as needed. Wax with a non-abrasive mild wax in the spring and fall. Use a clean, soft cloth and always rub lightly with the grain of the aluminum. "
http://www.airstream.com/cgi-bin/faq...&id=1017428689
JP
JPAIRSTREAM is offline   Reply With Quote
Old 11-21-2002, 10:27 AM   #14
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Walbernize Super-Seal is the product to use. There is another Walbernize product for use with the older clear coat units. Perhaps the person at the dealership was thinking of this.
During the factory tour at Jackson Center we were told that Super-Seal is the product to use and my dealer supports that statement.
As far as washing your trailer, we have a large thread here about that topic. It started off with my original question and goes and goes.
http://www.airforums.com/forum...=&threadid=182
Bottom line I recommend Armor-All car wash liquid. It contains nothing that hurts the finish on your new trailer.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
2003 international
Which clearcoat? Bob Thompson Clearcoat, Exterior Paint & Trim 13 05-27-2004 07:36 PM
Clearcoat mystery for Airstream... TomD32 Clearcoat, Exterior Paint & Trim 1 09-23-2003 07:03 PM
Clearcoat choice? TomD32 Clearcoat, Exterior Paint & Trim 4 09-23-2003 05:16 PM
'92 paint vs. clearcoat fangthorpe Clearcoat, Exterior Paint & Trim 1 06-22-2003 11:23 PM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 08:01 AM
