Old 07-31-2006, 05:40 PM   #1
Darrell Root's Avatar
2004 28' International CCD
Camarillo , California
Tow vehicle/Trailer match
Thought I had a perfect tow match but got concerned after reading about possible trailer damage from HD tow vehicles. I tow a 28' CCD GVWR #7300, with a 2003 Suburban 2500 8.1 liter autoride,3.73 rear. Is this a match without modifications. Darrell
Darrell Root is offline   Reply With Quote
Old 07-31-2006, 06:13 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Yes. The 2003/2004 2500's actually ride softer than my 97 1/2 ton. You should not have any problems with this setup.
Uwe
www.area63productions.com
Old 07-31-2006, 09:13 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Darrell -- I fully agree with uwe. I've had a smooth riding 1/2-ton Nissan Titan and now a 3/4-ton GMC truck. The GMC ride is a bit more busy but not in the least bit harsh. You couldn't tow a 28-footer with anything less than a 2500, so sleep easy tonight!
5 meter Langford Nahanni
Old 07-31-2006, 09:26 PM   #4
Link
Thanks guys, no offense to Andy of Inland, but sometimes after reading his threads ,one has a tendency to worry about things I never even thought about. You probably guessed I was reading the honda gen. mount thread. Darrell
Old 07-31-2006, 10:02 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Don't forget that the truck may be more heavily sprung on the rear axle because they were designed for hauling stuff in the bed. I'd like to see a comparison, picture wise and stat wise, of the same year 2500hd and the 2500 Suburban rear leaf springs.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-31-2006, 10:06 PM   #6
In retrospect
I now remember we test drove many 2500 HD trucks and the Suburban was a much softer ride. The Allison trans. wasn't available on the Suburban 2500 which I would have liked ,but the trade of was the ride. Darrell
Old 07-31-2006, 10:21 PM   #7
Darrell -- Airstream frames have changed over the decades and have tended to become beefier. My Argosy frame is a lightweight compared to our Safari, yet nothing prepared me for the scanty amount of material on a Minuet frame. I believe Inland Andy has seen a lot of the damage he reports. I'd wonder about a more detailed comparison of damage by frame type. Generalizing is a human and sometimes humane characteristic in telling our tales. Me? I'll blame a lot of damage on the rocking ride of some of these older truck-damaged poured concrete highways!
Old 07-31-2006, 11:20 PM   #8
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
I wouldn't trade my 2500 HD except for a newer one
There are many things to worry about when towing your Airstream. So far my Silverado (now teamed with the Hensley) has greatly reduced my worry list. My contrarian two cents (and I don't discount Andy's wisdom). Having said that I've been reading about an economical air suspension system from Firestone that I might try to soften the ride. A non surgical approach. I also don't max out my tire pressure.
-KL
4CU Charter Member
silverback is offline   Reply With Quote
2004 international
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 10:14 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 01:18 PM
tow vehicles paul k Tow Vehicles 96 01-19-2003 10:59 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 08:04 AM
Tow questions ALANSD Airstream Motorhome Forums 3 05-28-2002 10:51 AM
