Originally Posted by JBMcG
The shower head unit at end of flex hose in most RV's is pretty std residential plumbing item.. It is possible to find repacement with shutoff in regular hardware store (Home Depot/Lowe's) or units with slide valve for trickle (to avoid hot/cold issues when re-opened..) at most RV stores, including Camping World etc... Unit removes from threaded fitting at end of hose with wrench, and new unit goes on with some sealer or teflon tape to make it water tight...
John McG
Not quite as simple as that with the CCD. The shower head is a pull-out faucet head in the corner sink. When I had the International AS, I had the same problem; I searched every HD, Lowe's, and plumbing shop around and never found a suitable replacement head. All were too large, too long, or angled in a way that wouldn't work with the corner sink. I finally lived with what came with the trailer.
One option is to pull out the hose, unscrew the head, and screw on a better head just when showering. One caveat is that if the hose slips down the faucet spout, you have a real problem getting it back. Also, an adapter nipple is required since the threads on the AS head are opposite those on a standard head.
