Most modern, electronic tuned televisions have a "broadcast/cable" selection when setting up your television. It is in the main menu with the channel setup options. Make sure it is highlighted on "cable", and let the TV find all available channels. If you then go with your antenna, make sure you change the settings accordingly, and have the TV re-search available channels of broadcast.
