Congratulations and welcome to the club!
We went from 22 to 25 aswell and love it!!
Originally Posted by silverback
Ours came with the black tank flush system (built in April). Not sure if the tank monitoring panel is quite happy (could be me not having read the manual yet). Right after dumping the tanks, it still showed the black tank full (something to do with the tank flush I tried?). Wheel torque checks showed nothing loose. Did find some loose, and or missing hardware and also some of the usual CCD finish peculiarities. It's wide!! Did I mention it's wide?
By the way our 25 CCD's computer had (still has...) the same exact problem!!! We have taken it back to the dealer to get this problem fixed several times. Many parts were changed and various attempts were made but they were all unsuccessful.
We don't live close to the dealer and at the end of last season we had lost faith in them getting this problem fixed when they called us and told us that someone down at Jackson center had an idea on why this was happening:
Apparently Airstream must've calibrated the sensor in the black tank when it wasn't completely empty, so now it shows full immediately!!
The fix is simple: empty all tanks completely and re-calibrate the sensors.
Unfortunately we had winterized already so have not yet tried this solution. We've de-winterized last Sunday and don't plan in taking it back in to the dealer until the end of this season. We need to leave it there for some time since there are still several other things they did NOT repair as they should've...
Give it a try guys it may just be the right solution. Let us know!
