Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2002 - 2005 International
Old 10-28-2015, 09:15 PM   #41
2014 19' Flying Cloud
Eugene , Oregon
I am not sure if I commented to this particular group or not. Contact the coolerguys.com and tell them your story. Our fan drove us nuts, until the pressed bearing finally gave way, the impellers (fan) slipped off center, and the darned thing finally died. We replaced it with a 120 mm Gentle Typhoon 1850 RPM cooling fan from GentleTyphoon 120mm Silent Case Fan Series D1225C12B 1450,1850 and 4250 RPM. It is very quiet and really moves the air. I tested it on a hot day and am so pleased that I recommend it highly. You can call them for personal help. When it is running, it is barely perceptible, soundwise. The AS factory fan sounded like mower running.
Dave-Nancy is offline   Reply With Quote
Old 12-31-2015, 06:52 AM   #42
2003 22' International CCD
East Durham , New York
Hi, just bought the fan but which wire is positive and which is negative? And which goes to the fins on the fan and which goes to white power wire? Thanks for your help!!!!
bluvalley is offline   Reply With Quote
Old 12-31-2015, 09:57 AM   #43
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I am not entirely familiar with your situation but I think the picture below will help. Most fans come with three wires and the configuration of the wires is important. Many fans will not suffer adverse consequences if "+" and "-" are reversed - the fan will turn on but rotate backwards if you mix + and -. But if you connect power to the tachometer signal pin you may make the fan inoperable.
Note the orientation of the tabs on the connector so you can identify the correct wires.
Hope this helps. I'm sure others will add or correct as needed.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 01-01-2016, 07:49 AM   #44
so the fan is either turned on manually or turned off manually. not governed by temp. as our original fan was once switched to the on position with the toggle switch inside the trailer. do i understand this correctly?
dsrtgrls is offline   Reply With Quote
2004 international
noisy refrigerator fan Turtle 1997 - 2004 Bambi 9 06-03-2004 03:45 PM
Furnace Fan qbee Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-30-2004 05:41 PM
Loud range hood fan lbrodsky 2000 - 2004 Safari 5 09-26-2003 06:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
