Old 10-02-2002, 11:39 AM   #1
2002 22' International CCD
Garden Grove , CA
Noise dry camping
Dear Group,
When we were out (first time) we ended up dry camping.
The refrigerator was on gas. There was a noise coming from the refrigerator. If you are not level (and we knew we were slightly off and getting boards to prevent this in future) is there a fan or something that turns on for some reason?
I have the refrigerator on (gas) in the driveway and there is no noise.
Anyone know anything about this? Thanks.
Christine
CCD 2002
ChrisAich is offline   Reply With Quote
Old 10-02-2002, 05:55 PM   #2
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
There is a fan in the Refrigerator cabinet. If the temp goes over a certain degrees the fan will turn on to circulate the air thru cabinet. This will help the refrigerator operate correctly.
JP
JPAIRSTREAM is offline   Reply With Quote
Old 10-02-2002, 05:57 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Hi Christine,
I read that a propane refrigerator should not be more than 1/2 bubble off level. Do you think it was more than that when you heard the noise?
Your noise could come from multiple sources, for example it could be a slight noise from the burner, or it could be your ammonia inside the refrigeration unit bubbling, if you were too far off level, or it might be a ventilation fan for the cooling unit that you are hearing. Hard to tell without a closer description. If it does not make the noise when level in your driveway, then it might have been caused by the trailer being off level.
Are you sure it had to do with the refrigerator?
Uwe
www.area63productions.com
Old 10-02-2002, 06:18 PM   #4
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
It's the fan
A/S had to install a fan because in the Internationals, there is no rooftop vent to provide convection cooling of the fins.
On a cool night, you will hear the fan cycle on and off as the burner cycles. On a warm day, the fan will run continuously. The fan is on a thermal switch and will start 15-20 minutes after the refrigerator is initially turned on.
IMHO, the fan runs far too fast and needs a series resistor to quiet it a bit.
John W. Irwin
WBCCI #9632
Old 10-03-2002, 11:55 AM   #5
Garden Grove , CA
Re: It's the fan
You're right. It was the fan. I'm just not used to the small hum of that fan being on. In the quiet of a campground it sounds so loud. I'm just used to stone quiet when I'm napping or sleeping in the bedroom at night. I think I'm just going to have to get used to it. Sorry for the fuss.
Christine
Old 10-03-2002, 11:58 AM   #6
Garden Grove , CA
Originally posted by uwe
Hi Christine,
As it turns out, I've made a big fuss over a naturally occuring function. The fan. It's just doing it's job. Duhh. At night when everything was so quiet, it seemed SO loud.
Thanks for your response. I'm lucky I have my fan on the other side of the trailer from the door. At least it will always work. I will look forward to the fan cycling *off*. Thanks for your response.
Christine
CCD
Old 10-03-2002, 12:00 PM   #7
Garden Grove , CA
Thanks JP. I sat in it yesterday with everything fired up. Definitely the little fan and I will have to sit out there a lot and work on getting used to that sound. Looking forward to hearing it cycle *off*. lol.
Christine
CCD
Old 11-11-2002, 12:26 AM   #8
betteleal's Avatar
2007 28' International CCD
las vegas , Nevada
Red face
It takes a little getting used to, but eventually you won't even hear the refrigerator fan. The worst part is in the beginning when you hear it and don't know where the noise is coming from and why there is that noise.. time will take care of it. we just returned from our first rally (Nevada unit) in Mesquite (dry camping) yes, the noise was there but hardly noticed it. Was ab le to get to sleep after all.
Bette Leal
2003 International CCD
WBCCI #4454
Las Vegas, NV
betteleal is offline   Reply With Quote
Old 11-11-2002, 08:04 AM   #9
hex
hex's Avatar
Thumbs up Thanks for the question.
Christine
Fuss? Not hardly Christine.
These questions are the little ones of REAL Value to so many of us newbies (and prob'ly some oldies as well). There is no other place to get these factoids. So IMHO it is imperative that nothingAirstream ever be considered too trivial to ask. Thanks.
Now would someone define ~~~dry camping~~~ to me. Is the other kind of camping ~~~wet camping~~~?
hex is offline   Reply With Quote
Old 11-11-2002, 10:10 AM   #10
Contributing Member
Pahaska's Avatar
There's another fan, also
There is also a fan in the AC/DC converter that you may hear from time to time. I was working in the trailer the other day with every light and both Fantastic Fans turned on. The fan in my converter cycled on and off a couple of times during the afternoon (outside temp was about 90 degrees).
John W. Irwin
WBCCI #9632
Old 11-11-2002, 10:39 AM   #11
Diana Langley's Avatar
Images: 13
Send a message via Yahoo to Diana Langley
Rivet Wet/dry camping
Dry camping is when you are camping in an area without any kind of water or electrical hookups.
Diana Langley is offline   Reply With Quote
Old 11-11-2002, 10:48 AM   #12
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I have also heard that called boondocking.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 11-11-2002, 10:53 AM   #13
Images: 13
Rivet
Maybe it's a Southern California thing. I usually head for the desert when I camp.
Old 11-11-2002, 01:11 PM   #14
Garden Grove , CA
One more thing on the refrigerator fan. A friend suggested I may have the refrigerator set too high. Bingo, I turned it down to 4 and it cycles off more than it runs and keeps everything cool. Of course it hasn't been hot here either. So, I'm sure if I'm traveling in heat I'll have to turn it up. Oh, well.
Christine
2003 international
How did you get into camping? yukionna Our Community 51 07-23-2007 01:54 PM
"Our First Camping Trip" Silvertwinky On The Road... 17 10-01-2003 08:35 PM
Dry weight variances Moonshot On The Road... 1 09-11-2003 09:06 PM
Camping grins Rog0525 Off Topic Forum 38 07-31-2003 02:26 AM
Dry camping Tripp On The Road... 2 01-09-2003 04:15 PM
