Old 10-26-2005, 09:22 AM   #1
nangoff's Avatar
2004 28' International CCD
Franklin , Tennessee
LED Replacement for Halogen Cabin Lights
Has anyone come up with a LED replacement for the halogen cabin lights on the CCD's?
The halogens pull too much power.
I'm thinking there is, or soon will be, a g4 based led to insert into the socket the 10 watt halogen now occupies.....or there might be a complete lamp assembly to insert in the cabin cutouts.
Any help would be appreciated.
Gerry Goffinet
CCD 28, 2004
goffinet@comcast.net
nangoff is offline   Reply With Quote
Old 10-26-2005, 12:45 PM   #2
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
I've already got you covered, complete with pictures:
http://www.airforums.com/forum...-halogens.html
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 10-26-2005, 09:17 PM   #3
nangoff's Avatar
What do you think about this product?
Certainly looks powerful enough, do you think it will fit in the lamps?
http://www.ultraleds.co.uk/default.p...e0473d34043030
Gerry
Old 01-11-2008, 10:26 PM   #4
nangoff's Avatar
I did buy some of these lights, and I also replaced the factory supplied 10 watt bulbs with 5 watt ones. The light of the LEDs I'd describe as slightly less than a 5 watter which is less that a 10 watter. If I put the light output of a 10 watt halogen at a 10, I'd put the light output of a 5 watt halogen at a 7 and an LED assembly at a 5. Gerry
Old 01-12-2008, 09:20 AM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Try this link:
http://www.airforums.com/forums/f447...ens-17392.html
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-13-2008, 03:18 PM   #6
nangoff's Avatar
You can pretty typically get halogen bulb replacements (G4 bases) with LED arrays now on e-bay for about $15 (less in quantity) on e-bay.
eBay Motors: G4 White 14-LED Light Bulb Sailboat Boat Halogen Cars (item 190181704065 end time Feb-05-08 08:53:55 PST)
Has anybody tried some of these units from this vendor?
Gerry
Old 01-13-2008, 05:09 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I tried the LED replacements, and here is what I found:
Pro: cool running, low energy consumption, rugged for travel, small size.
Con: light color is terrible. Light output lower than the halogens. OK perhaps for accent lighting inside the CCD roof lockers, but unpleasant light color for task lighting. I took them out and re-installed the 10W halogen lamps. The aura returned..
Keep in mind that in the old days the 4 bulbs in a 70's trailer's roof fixture were up to 84 watts. 4 of the halogen floods make much better light at only 40 watts. Replacing those 4 halogen lamps with 5W units reduces this to 20 watts. Hardly a large draw on a healthy batttery, even during a few days of boondocking. That's about .2A.
I'd be more worried about the current draw of a furnace, water pump or 12V powered fan. Lamps are only needed for alimited time each day, anyways.
Uwe
www.area63productions.com
Old 01-13-2008, 06:18 PM   #8
2005 22' Interstate
Afton , Virginia
Uwe, I don't understand your last paragraph. I'm not trying to sharpshoot you, but if you have a 12 volt battery, 20 Watts would be .6 Amperes, wouldn't it?
regards
herrgirdner is offline   Reply With Quote
Old 01-13-2008, 06:22 PM   #9
2005 22' Interstate
Afton , Virginia
Correction
In my last post, I left off a "1". Read 1.67 A vice .6A. Sorry
Old 01-13-2008, 07:05 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Hey Gang,
Imtra Marine makes/sells a direct replacement LED light that will fit perfectly into the G-4 halogen fixtures of the newer Airstreams. I have replaced ALL of my halogens with these.They have a slightly lower visual output, but I find the light level from these most acceptable.
Be sure to order the 'warm white' style, as this quality of light is virtually identical to the 10w halogen bulbs found in the AS. The 'cool white' is very blue and harsh!!
Old 01-13-2008, 07:36 PM   #11
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
http://www.airforums.com/forums/elec...-halogens.html
That URL doesn't work for me. Looks like the parent forum was renamed/relocated. This one does:
Maurice
Old 01-13-2008, 07:59 PM   #12
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
You're right, of course. I meant to write 2A, instead of .2A, while 1.67 is much closer to the formula.
Uwe
Old 01-13-2008, 09:28 PM   #13
nangoff's Avatar
I have yet to find any definitive lumens output of any of these LED arrays compared to classic halogen of 5 or 10 watts. Has anybody got a definitive lumen output of the LEDs?
Also, is the comparison of lumens between light sources linear or exponential? Example, is a 10 lumen light source twice as bright as a 5 lumen source or is it 4 times as bright?
Thanks, Gerry
Old 03-03-2009, 01:25 PM   #14
wppii's Avatar
East Nicolaus , California
Images: 33
I have replaced the dinig area lights with these
G4 LED lamp Specifications
Minor decrease in intensity, didn't have warm white when I got them but I like the power savings. I have the 6 bulb model, no problem with polarity in the socket
The Lovin' Oven is an 04 28' International CCD.
It follows where the F150 Supercrew leads.
"The only time to say "No" is when they ask if you've had enough"
wppii is offline   Reply With Quote
2004 international
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
replacement tail lights for '69 Airstream bgow 1965 - 1969 Overlander 0 08-06-2002 10:03 PM
