Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2002 - 2005 International
Old 10-01-2008, 06:58 AM   #1
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
CCD galley cabinet modification
We have a 2005 28' CCD and the galley cabinet door has a sharp edge that rubs the lounge/sofa when the door is opened and closed. It it starting to leave a wear mark on that upholstery.
I am thinking of taking a router to that edge with a rounding over bit and eliminating that edge.
Has anyone had this problem / used this as a solution?
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 10-04-2008, 12:16 PM   #2
Fulltimer
Regele1's Avatar
Long Beach , California
Have you tried adjusting the door, I have the same airstream and mine doesn't have that problem.
Regele1 is offline   Reply With Quote
Old 10-04-2008, 12:51 PM   #3
2002 19' Bambi
Lafayette , California
I have no way to check on a CCD's cabinet construction, but I do know that our 2002 19' Bambi had sharp edges (sharp enough to cut) everywhere on cabinets, cabinet doors, and cabinet frames. In all cases it was the "edge banding" that was the cause. I spent a number of days smoothing all of the sharp edges of the edge banding so that they were pleasant to the touch. I did not use a router because of how easy it is to lose control if the piece being worked on is not fastened thoroughly to my workbench. What I did use is a mill-cut file, something I have used many times for formica work. Each pass with the file takes off only a small amount of material, so mistakes are much less likely.
Tim A. is offline   Reply With Quote
Old 10-04-2008, 06:29 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We got tired of scraping our arms on the edges of the cabinet/table tops and cabinet edges, too...we added aluminum edging to a lot of places...it looks great and you'd think it had always been there...
Name:	Aluminun Edge_02_Sm.jpg
ID:	68789   Click image for larger version
Name:	Aluminun Edge_03_Sm.jpg
Name:	Aluminun Edge_04_Sm.jpg
ID:	68791   Click image for larger version
Name:	Aluminun Edge_01_Sm.jpg
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
2005 international
Modification Required For Uk maggi1972 Shipping & Export/Import 3 08-12-2007 02:48 PM
Galley Puzzle Cat Cabinets, Counter Tops & Furnishings 9 10-07-2006 05:26 AM
CCD Overhead Cabinet Dimensions? swebster General Motorhome Topics 35 12-02-2005 11:40 AM
CCD Modification frozen chosen Airstream Trailer Forums 0 04-07-2004 07:29 PM
Galley plumbing Ufatz Fresh Water Systems 8 06-17-2003 09:25 AM
