Old 06-16-2003, 11:56 PM   #1
KIMILI's Avatar
2004 25' International CCD
Salem , Massachusetts
BEST TOW VEHICLE FOR 22' ccd ?
Help: our CCD is sitting at the dealer!
we're brand new owners in need of a good tow vehicle for our 22'CCD.
We're planning to move to SF (2 adults, a dog & a puppy) and have some concerns.
We've been shopping for over a month now and the more we see the more confused we get, (every dealer has his advice...but no experience).
In need of real life experience. Any advice really apreciated. Thanks.
We need something:
- not too pricy (25K tops)
- OK with California emission laws
- great gas/mileage (planning a lot of towing)
thank you
Kimili
KIMILI is offline   Reply With Quote
Old 06-17-2003, 05:32 AM   #2
Vroom
Richard Vroom's Avatar
Mahone Bay
Images: 14
Best Tow Vehicle
We are considering the new Toyota Four Runner for our Sovereign 25. It tows 7200 lbs and has air rear suspension to adjust for the weight of the load. It gets better than average fuel consumption and rides like a lexus. Torque is 320. Try driving one and you wil lsee what I mean.
Richard
Richard Vroom is offline   Reply With Quote
Old 06-17-2003, 06:25 AM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
If it were me, I'd look for a used 2500 GM Suburban, or 2500 extended cab pickup. But, that's me.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-17-2003, 07:36 AM   #4
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Although the advantage of a trailer is that it can be towed with other than a pickup truck, I wouldn't do it. There are things I don't want in the passenger compartment, especially in an accident. Heavy things like generators or 5 gallon cans of extra fresh water. Flammable things like a 5 gallon can of gas for the generators or an extra propane bottle, Nasty things, like a tote tank. Greasy things, like a gas grill. Muddy things, like a patio rug, lawn furniture, blocks and chocks, and sometimes hoses and extension cords. So I'd opt for at least an Extended Cab pickup, and maybe a Crew Cab if the dogs are large breed.
I do like 4WD, especially one with Low Range, if you're gonna go to rallies or other events where you may find yourself out in a field.
Congratulations, and best wishes.
Maurice
Old 06-17-2003, 07:44 AM   #5
Chas's Avatar
Images: 22
Another vote for either an extended or crew cab pickup, 3/4 ton with a topper and a long bed. Largest gas engine or diesel (my preference). Just don't plan on parking it in S.F. too much and you'll be allright. Take BART!!
Chas
Chas is offline   Reply With Quote
Old 06-17-2003, 07:55 AM   #6
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
Pickup
I tow my AS with an extended cab Silverado with 5.3L engine. With 3.73 gearing, this is more than enough power for the CCD. I have the 4WD (Z71) package and it is nice to have for wet conditions or for starting up on bad surfaces such as loose gravel.
Unfortunately, my Silverado has 3.55 gearing and I had to put on the Banks system to compensate. This would not be needed with a better rear end ratilo.
John W. Irwin
WBCCI #9632
Old 06-17-2003, 09:50 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Although it is within the cars towing ability, I went with the Bambi instead of the CCD. Based on the GVRW of the CCD, it fits within the realm of acceptable if you get a good hitch, weight and sway bars. The Caprice or Impala SS from years 1994 through 1996 with an LT1 engine would be able to tow the 22' CCD without any problems. Next in line would be a truck of some sort be it 1/4 ton or higher with tow packages. You need to know that the engine outlined above in the Caprice/Impala is the very similar, if not the same engine/transmission found in the Chevy trucks of similar years. The reason the Caprice/Impala should not pull the 25-34' units is due to the frame not meeting the 1/4 ton capability and that is where the truck win with the larger units with the ability to handle larger tongue weights. Anything in the 5000-5600 range the Caprice/Impala can do and the cars can be bought new for between $8-$15k depending on mileage and condition.
As for gas mileage when towing, expect about 10mpg on average. I got lucky on the trip home from the midwest rally and got about 15mpg due to the wind pushing us along. That is truely rare. The nice thing about the Caprice/Impala is that when not towing gas mileage city is about 14 and hwy about 23 (assuming a somewhat liberal foot..non liberal feet get better gas mileage across the board).
Eric
Old 06-17-2003, 10:40 AM   #8
Raptorrider2001's Avatar
Richardson , Texas
Images: 14
Cool
I bought my Duramax Chevy diesel thinking we would buy a larger trailer. When we bought the 25' Safari, I figured the Duramax was overkill for the A/S. Turns out to be a perfect match up. Would do it again in a "Heart Beat". And, the Allison transmission is teriffic for gearing down on steep grades. Best mileage so far pulling the Safari has been 15 1/2 mpg. Usually average around 13 1/2-14. About 15 solo around town and 18-20 solo on the highway. Best has been 21 1/2.
'99 25' Safari
2 Honda 2000i generators
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 06-17-2003, 12:20 PM   #9
KIMILI's Avatar
making the right choice
Thank you all for the great advice!
We have been to most dealers and test driven just about anything.
The 4runner is hot but pricy compared to others, here it runs (fully equipped) around $41!
After reading all related forums on towing we were definetly pushing for a 4X4 extended cab pick up. Our dogs are a Husky and a Shepard mix, they would welcome the extra room and so would all that extra stuff you have to take along.
Our worries are in purchasing a Diesel here, moving to California (beg. 2004) and not passing their emission test, having to sell the truck there and be stuck!. Also since we do drive an average of 22'000 a year the gas mileage was a concern. We plan a lot of towing.
If anyone has recent reliable info on which diesels are allowed in Cali it would be great!
We're considering the use market and would apreciate any specific model suggestions.
The sooner we solve this the sooner we can go and retrieve our CCD and hit the road.
Thanks again everyone.
Old 06-17-2003, 03:04 PM   #10
2001 34' Limited
The State of , Ohio
If you don't buy at dealer invoice, the diesel option can run $5000 or much more. As much as I like it, 4WD can make a $4000 price difference.
You don't need to spend the extra for a 3/4-1 ton truck with a 22' CCD, a 1/2-ton will do, as will a small-block gas V8. As John mentioned, a 3.73:1 axle ratio, definitely with limited slip whether you get 2WD OR 4WD, is a must, and will get you through most hills. A 4.10:1 is better if you're going to spend a lot of time in the mountains with a small-block, but you'll pay for it in highway fuel mileage when not towing. Doesn't make a lot of difference around town.
An auto is a little easier when parking, and will give better resale value, but if you go that route, make sure the truck has the factory towing package, which besides the hitch and wiring, often has a larger or auxiliary transmission fluid cooler.
And as much as I like a long bed, if you're going extended cab, a short bed makes it much easier to manuver and park. It's plenty long enough for a 22'.
The mid-line trim package is usually the way to go. It often has the essentials, such as air-conditioning, etc and often doesn't cost much more than a stripper with essential options. And it is MUCH less expensive than the top of the line trim with leather, etc.
Try to find a dealer that will sell at $300 (not just 3%) over invoice. They're out there.
You'll usually get a better deal buying off the lot rather than ordering. Don't know about the others, but if you can search dealer inventories on Ford's website.
Hope this helps.
Maurice
Old 06-17-2003, 11:24 PM   #11
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
Re: making the right choice
You're worried about something that is not a problem. As long as your vehicle has over 7500 miles on it CA can't make you do a thing. CA emissions only concern new vehicles. The 7500 miles sticker is to keep CA residents from driving across the border to buy a non-CA emissions vehicle.
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 06-18-2003, 11:41 PM   #12
KIMILI's Avatar
Unhappy ca diesel
Great!
thanks for the tip on CA emissions it really helped.
We're now concentrating our search between these 2 models:
Ford F250 Diesel V8 7.3lt
Chevrolet Suburban V8
Diesesl here are so hard to find that dealers don't even want to consider price talks...
Old 06-29-2003, 12:19 PM   #13
skipj's Avatar
A few comments from a duramax owner, my mileage agrees with those mentioned above. About 16 on the highway at 60 to 65 towing a 25í classic, and 20 on the highway solo. City sounds about right. I have a GMC 250HD crew cab with the short-bed and 4wd. My dislikes are the hard ride especially without a load, and the turning radius. I traded an extended cab diesel with full size bed for it. The new vehicle seems to turn tighter but still not like a 2wd. I camp in fields and other non-campground environments so the 4wd is important to me. I read that Jeep was coming out with a small diesel in their Grand Cherokee in 2004, but it sounds like you arenít able to wait.
Skip J
89 25' Excella
92 B-van
skipj is offline   Reply With Quote
Old 07-13-2003, 05:21 PM   #14
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Two weeks (?) till delivery
We will be using a an 03 Toyota Tundra w/towing package for an 03 CCD.
KL
silverback is offline   Reply With Quote
2003 international
Tow vehicle wheel base flynmike Tow Vehicles 15 05-09-2011 09:27 PM
Tow Vehicle for 27' Overlander pyrenees Tow Vehicles 9 05-06-2011 09:18 PM
The ultimate tow vehicle! I found it! brad1 Tow Vehicles 8 03-21-2011 08:47 PM
