Old 03-03-2015, 08:33 PM   #1
Verona , Pennsylvania
Absence of Propane to furnace
I had let my furnace cycle out & use up the propane in my tanks.I filled my tanks & replaced them now I have gas to my stove but not to my furnace. Any solutions?
Melisirish is offline   Reply With Quote
Old 03-03-2015, 08:42 PM   #2
GeocamperAS's Avatar
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
It might just be that there is a lot of air in the line. The furnace burner will not light until the pilot is lit and stays lit. The pilot is a very small hole and uses very little gas. It may take a few minutes to bleed all the air through.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 03-03-2015, 08:47 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
If it is a newer trailer with electronic ignition, there is no pilot. But you may have to try to light it several times to bleed the air from the line.
Al
Absence of Heat... STREAMTEAM Off Topic Forum 20 12-30-2007 01:17 PM
Re-introduction after a year long absence eddofec5 Member Introductions 18 07-10-2007 06:35 PM
Back after a 30 yr absence...... commander31 Member Introductions 17 01-11-2007 09:44 PM
