I had let my furnace cycle out & use up the propane in my tanks.I filled my tanks & replaced them now I have gas to my stove but not to my furnace. Any solutions?
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
It might just be that there is a lot of air in the line. The furnace burner will not light until the pilot is lit and stays lit. The pilot is a very small hole and uses very little gas. It may take a few minutes to bleed all the air through.
Judging a person does not define who they are, it defines who YOU are.
If it is a newer trailer with electronic ignition, there is no pilot. But you may have to try to light it several times to bleed the air from the line.
Al
