Old 08-20-2016, 01:45 PM   #1
Cristobal's Avatar
1988 34' Limited
Brunswick , Georgia
Drain valves
When I fill the fresh water tank, I get a leak underneath the camper. I assume there are drain valves somewhere?
Cristobal is offline   Reply With Quote
Old 08-20-2016, 03:37 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Good assumption. Time to do some looking around in dark places.
MICHAEL
Old 08-20-2016, 06:38 PM   #3
1979 23' Safari
Wayland , New York
Drain valve should be on the end of the pan holding the tank up, normally on the street side between the wheels.
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Another question - Drain valves kamadeca Waste Systems, Tanks & Totes 12 07-24-2004 11:29 AM
where are water drain valves/1990 Excella 32' ? femuse Plumbing - Systems & Fixtures 3 04-28-2003 09:13 AM
Drain valves on '79 Sovereign smily 1974 - 1979 Sovereign 3 01-28-2003 11:09 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
