Old 11-05-2016, 11:36 AM   #1
1988 34' Limited
Folly Beach , South Carolina
Zip Dee awning
So I have a few threads going and thought it best to separate my topics. My zip dee will not retract. It seems to be frozen on the forward side and I'm afraid I'm going to break it if I force it. Any suggestions?
Daddyo_1 is offline   Reply With Quote
Old 11-05-2016, 01:10 PM   #2
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
Hey Daddyo,
Just had to say it. Your spring inside of your awning may have broken. If that is, in fact, the problem it is an easy fix. Zip Dee will send you a spring ad they are not expensive. Installation is DIY.
Chatooga11 is offline   Reply With Quote
Old 11-05-2016, 01:55 PM   #3
Central , Mississippi
Name:	ImageUploadedByAirstream Forums1478372080.517007.jpg
Does your awning have the little locking arm like mine? The small curved lever with the hole in the end?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 11-05-2016, 04:59 PM   #4
1994 30' Excella
Mississauga , Ontario
What Hiho refers to is a Z-lock. It is intended to lock the awning in the closed position.
If it is locked while the awning is open it will not roll up.
Also Zip Dee says not to lock the awning when in use.
Al
Al and Jean
TAC ON-3
Old 11-06-2016, 12:57 PM   #5
1988 34' Limited
Originally Posted by HiHoAgRV View Post
Attachment 274840
Yes it does, I pulled it down before trying to pull it out, but it seems to still be in the locked position. The awning will only move about an inch or two
Old 11-06-2016, 01:05 PM   #6
1988 34' Limited
Name:	ImageUploadedByAirstream Forums1478459106.651872.jpg
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 03:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 11:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 09:12 PM
Zip-Dee Awning Repairs ViewRVs Awnings 3 08-31-2006 07:28 PM
Zip Dee awning problem DbackFan Awnings 12 04-06-2003 02:47 PM
