Old 08-23-2008, 04:51 PM   #15
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Well.. thats good info. The flooring would have looked great all the way up to the couch but as i look at the pictures again i do like the contrast in the flooring with the carpet towards the front of the coach separating the kitchen from the forward area. Great job.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 08-29-2008, 11:18 PM   #16
moderator
Airslide's Avatar
Wilton , California
Images: 50
Does the S/O drive motor sense if there is too much drag on the slide while operating outwards and stop supply voltage to the motor? Im wondering because when i operate the slide it only moves about an inch and then stops and when i hit the switch again it repeats the same cycle about 3 or 4 times until it starts moving normally and extends outwards to the stop. Coming in its fine. The slide appears to line up fine from the outside and it looks good and even when it comes into rest. This unit was in dealer inventory for several years and used by the owner (not sure how kind they were to it.) I know when i picked up the trailer the slide was open and the jacks were not down. Should i open a new topic on this issue? anyone have any thoughts?
Thanks Vinnie
Old 08-30-2008, 05:36 PM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Thanks Vinnie
Vinnie, I've not encountered that issue before but if it is happening consistantly my gut feeling is that you might be correct that some type of drag is going on. Obviously the dealer should have put the jacks down before extending the slide. Maybe some lube is in order. I remember my manual said something about lube. I've never done it though but our trailer isn't out a lot and it's stored in a nice dry inside environment.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-30-2008, 08:31 PM   #18
moderator
Airslide's Avatar
Wilton , California
Images: 50
Thanks Jack,
I see that there is a panel down under the slide area under the trailer. I think I will take that down and see how it all works. Maybe I can have someone operate it while i see it slide. If it appears to bind i will spray something on it to see if that makes a change in the operation. If it does then maybe there is a better grease to correct it longer. I hope that there isnt a big problem due to the twisting of the coach as the jacks were not down. I hope i hope. As I dig into things I see that there will be hours and hours of fun correcting things that need attention. My wife wasnt a big fan of this purchase but she will warm up to it. I have to be really quiet about all the problems and just fix them secretly (ha ha) otherwise i will take a lot of heat.
Airstream is in my blood now. I will keep you updated
Vinnie
Looking for an owners manual for 1976 Argosy 24' btophek All Argosy Trailers 21 06-08-2014 10:46 AM
Intro from the Blue Ridge of VA-99 Excella 30 Silver Otter Member Introductions 19 04-09-2011 05:21 PM
New Seattle Member with 1985 31' Excella Eugiepayset Member Introductions 4 04-08-2011 02:43 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
