Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1992 - 1996 Sovereign
Old 05-17-2017, 10:11 AM   #1
1994 21' Sovereign
Columbus , Ohio
Front screen door won't latch
The front screen door won't latch shut. The dog can just push right out. Any idea's on how to get it to latch again?
ID:	285735   Click image for larger version
kcox4434 is offline   Reply With Quote
Old 05-17-2017, 10:27 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
The door is not closing far enough to engage the latch. Find out what is stopping it. Any number of things could be possible:
1. Latch is not free to move - Hit it with some silicone lube.
2. Door is bent, contacting the frame somewhere and not allowing it to close all the way - Bend the door until it seats evenly on the frame.
3. The damaged frame shown in picture 1 is stopping the door from closing all the way - clean up the damage.
Al
Old 05-17-2017, 02:47 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The hinges are contacting the door frame preventing the door from closing.
They need to be bent back.
Try opening the screen door half way then push the door toward the hinges. It may take a block of wood behind the hinges to get them bent back.
Old 05-17-2017, 03:00 PM   #4
2008 27' Safari FB SE
Long Beach , California
I have a similar issue but mine may be less bent than yours. My door/hinges are a bit off so that if I allow the screen to simply close, it sits quite a distance from the latch catch. I have to pull it (which then bends the door to the correct position) to get it to latch.
Does yours bend enough with force to latch or does that not even work?
LBOskiBear is offline   Reply With Quote
Old 05-18-2017, 01:38 PM   #5
Sonoma Co. , California
Pics 2 & 3 show the latch mechanism is not aligned properly on the door frame. Holes in the latch mechanism allow for it to be mounted on the door frame and moved slightly to the left or right in order for the beveled latch pin to engage the pin slot. The latch pin has to seat into the slot deeply enough and with enough force to resist jumping out of the slot when pressure is applied to the door. Pics 2 & 3 show the latch mechanism is mounted all the way to the extreme left and no longer centered between the edges of the door frame. Perhaps the rivets attaching it to the door frame have loosened somewhat and the mechanism moved to the left from its original position. It needs to be moved to the right and centered on the door frame. Put a wood block against the left edge of the mechanism and tap it gently with a hammer to move it to the right until it is centered between the door edges. If it moves too easily and slides back to the left when the door is shut, the rivets are too loose and need to be replaced.
USAtraveler is offline   Reply With Quote
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
'74 Sovereign screen door / door latch? texasbound General Repair Forum 2 09-23-2012 05:48 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
What the devil is the screen door latch suppost IPM General Motorhome Topics 8 06-30-2004 04:13 PM
Screen door latch APB General Interior Topics 2 03-10-2003 08:06 PM
