Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1992 - 1996 Sovereign
Old 06-23-2019, 07:56 AM   #1
Free range's Avatar
1993 21' Sovereign
Red deer , Alberta
21' sovereighn hot water heater.
Just this spring we got our self a 93 21' sovereign, Now the hot water heater is underneath the corner bed and the top of the heater is almost touching the bed wood where the mattress lays on, and there is no Styrofoam wraped around the heater tank to keep the heat, are all hot water heaters naked without Styrofoam around it? You think I could spray foam the tank?
1993 21' Sovereign
Free range is offline   Reply With Quote
Old 06-23-2019, 08:14 AM   #2
Highland Village , Texas
There are other options which are probably better than foaming the heater.
- Fiberglass batting on the enclosure walls near the mattress
- Fiberglass jacket for the heater - you can buy these for regular sized water heaters, but you may have to cut one down for the AS
- Buy a fiberglass welders blanket (Northern Tool, any welders supply store, and wrap that around the heater.
Foam on the heater itself will be hard to apply, and may be a problem when the heater needs replacing.
DallaSteve is offline   Reply With Quote
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
being frugal with hot water — best ways to manage hot water cost lbdesign Full-Timing, Winter Living & Workamping 23 12-17-2015 09:14 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
