Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1974 - 1977 Overlander
Old 07-12-2012, 12:53 PM   #81
Dabrowa Gornicza , Florida
Some new photos:
Pawel002 is offline   Reply With Quote
Old 07-12-2012, 01:24 PM   #82
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
You are a true artist. I love the work you have done.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 07-12-2012, 11:09 PM   #83
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
It's breathtaking!
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
bolerama is offline   Reply With Quote
Old 07-13-2012, 12:02 PM   #84
salzburg , salzburg
Looking really good Pawel! how is the insulation holding up with the hot weather we've been having, was Baufol enough or should i be looking at putting something else on top of that as well?, Ill update my thread in the next couple of weeks but i'm nowhere near where you are at!! although i did replace my whole frame!!
mrgreen is offline   Reply With Quote
Old 07-13-2012, 12:58 PM   #85
We have more than 35'C last two weeks and Baufol works pretty well, but good think is painting roof on white, before painting I can't even tuch the roof in hot weather, now is "cold" . Few days ago I check temp on outside - 36'C and inside all day closed trailer, result is "only" 5'C more so it's not too bad.
I have problem with PrecisionTemp RV-500 , I can't find way how to plug in to euro spec propane instalation, I must try to go with this heater to LPG installer maybe they can help me.
Next I must looking for machine to produce money , I really don't want to know how much I spent for now
Old 08-14-2012, 10:53 AM   #86
Interior is almost done !! Only few minor thinks to do
I spend almost one month to find reducer from old water heater to euro 8mm gas pipe
When I find all needed parts I found big hole in heat element
Now i have new water heater
It's very light and works very well and new place for it is above axles
In winter it use hot air from furnace to hold temperature
This is a new furnace:
And I cover old holes from onan generator and water heater
Old 08-15-2012, 12:46 AM   #87
salzburg , salzburg
Pawel, respect, that looks fantastic, I bet you are pleased with the results, and i bet you are glad to be finished!! well done
Old 08-15-2012, 10:42 AM   #88
Thanks mr Green
this is 8 months of work, and I'm really tired now, but very happy
What about your trailer ? Do you have any progress?
Old 08-15-2012, 11:34 AM   #89
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Southern , Illinois
Pawel,
You have done amazing work and the result is that your trailer is beautiful and you know every inch of it very, very well!
Nancy Mac
maccamper is offline   Reply With Quote
Old 08-15-2012, 04:53 PM   #90
bolerama's Avatar
Images: 30
Absolutely stunning! You should have a job at Airstream.
Lisa
Lisa and Paul
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 09:26 AM
The Buddha Baby A Restoration wasagachris 1960 - 1964 Sovereign 136 06-30-2012 08:56 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
1966 Airstream Overlander Bob J. Mariano 1965 - 1969 Overlander 1 08-05-2011 03:44 PM
