Old 11-12-2017, 03:29 PM   #1
Buzzards Bay , Massachusetts
Floor Damage from leak around rear storage bumper
I️ recently purchased a 27 ft 1974 AS. After pulling out a bed that was constructed by previous owners I️ found extensive water damage. Ive established that the water is coming in at the seam between the floor and wall. As you can see in the pictures I️ could slide a screwdriver right through. Its also wide open along the sides of the storage box as well. Any suggestions on how to tackle the leak problem as well as replacing this section of floor?
Kay4477 is offline   Reply With Quote
Old 11-12-2017, 03:31 PM   #2
I️ apologize for the symbols. My phone replaced I️ for A ?
Old 11-12-2017, 03:37 PM   #3
ID:	298910Click image for larger version
ID:	298911Click image for larger version
Old 11-12-2017, 03:56 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Looks like classic rear end rot common to trailers of this age. You might be able to patch it or to replace the last entire piece of subfloor--depends on how extensive the rot is. The frame underneath is likely disintegrating as well. The first thing I would do is check the entire perimeter of the trailer for rot to determine how much floor needs to be repaired/replaced. The next thing would be to drop the rear most section of belly pan to see what the frame looks like back there.
Regardless of the fix, the deck of the bumper trunk is the real villain here--it funnels water right into the end-grain of the subfloor back there. You will want to get that interface sealed up as part of the fix.
Good luck!
Old 11-12-2017, 04:21 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Stand on the back bumper and bounce. If you the bumper moves more than a fraction independent of the coach you have "rear end separation" In the rear of the coach inside the wall is an angle iron which attaches the rear wall to the frame. Good chance it is rusted out. AS uses a "semimonocoque" design where the body of the trailer, the floor and the frame form a structural unit.Good chance the rear section of the floor needs to replaced, and maybe some work on the frame. Not an easy, fast or cheap job. unless you are up for it might be a good time to cut your losses.
Old 11-12-2017, 05:08 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Typical 70s rot.
Mine was much the same, additionally the frame on mine was rotten where the black tank was leaking on the frame.
The worst part of the repair was removing the old bath fixtures, my son and I replaced the last four feet of frame and the last sheet of plywood. It took maybe two or three days.
You will find the rear curved piece of c-channel rotten too. I had to reconstruct mine.
Old 11-26-2017, 10:36 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
FWIW, my trailer was worse..... or at least as bad. Persevere! Click image for larger version
Old 11-27-2017, 08:09 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello from Colorado: It is a rare original 70s trailer that doesn't have this problem. Many of them have been repaired, but many more have not.
I am a new owner of a 75 Overlander. It has a classic case of rear end separation which I knew when I purchased it. I've taken the bath and holding tanks out and have developed my repair plan, which I read about here on these Forums. Here is a photo of the floor and missing rear body support (due to rust out) of my trailer. Tisk, tisk, tisk.
Note: Airstream cut a lot of clearance holes in the last 8" of plywood subfloor for valves, vents and the like.
Your trailer can be repaired, either by you or a good repair shop. The repair cost is significant, but important. New England has several good repair shops if you want to farm the job out to someone.
And "while you're at it" I can think of several other improvement projects for your trailer.
David
PS: J Morgan: What a neat photo of a sleeping dog in an all wood Airstream interior. Makes me want to take a nap.
Name:	1711 Floor Rot Rear 2 (Small).JPG
Old 11-27-2017, 08:29 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
We love staying in that cabin, probably more than we should. It was worth every minute of construction time, and worth every dollar spent. It is way too cool.
Leak at rear bumper storage rotted floor inside A W Warn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 60 09-01-2018 10:47 PM
"PVC" Styled Sewer Storage/Rear Bumper Storage Repair Frank&Mike Bumpers & Bumper Storage 5 11-04-2010 09:30 PM
C Channel - Floor - Famous Rear Bumper Leak Soyboy Repairing/Replacing Floor &/or Frame 9 08-08-2010 06:57 AM
Rear bumper storage tray - 2004 Classic Ed Keyes 2001 - 2005 Classic 9 10-02-2005 09:50 PM
Rear bumper storage latch mystery Shelby Copeland Bumpers & Bumper Storage 3 12-02-2003 11:49 PM
