View Poll Results: Guess the tongue weight
under 250 lbs 3 9.68%
250 to 275 lbs 1 3.23%
275 to 300 lbs 5 16.13%
300 to 325 lbs 9 29.03%
325 to 350lbs 2 6.45%
Over 350 lbs 11 35.48%
Voters: 31. You may not vote on this poll
Old 05-13-2011, 07:47 PM   #581
constructor's Avatar
1973 25' Tradewind
Burnsville , North Carolina
Polishing is so dirty to then provide such a shiny finish.
Ann - The Constructor's scribe.
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
constructor is offline   Reply With Quote
Old 05-13-2011, 10:04 PM   #582
1973 31' Excella 500
Spring Green , Wisconsin
Looks great Chris! Like you, I haven't found much time to work on the AS. Life just keeps getting in the way. Sad she's not ready because now I have to go tent camping with my son next weekend.
Keep us posted on your progress and keep up the good work (like anyone really needs to tell you to do that).
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 05-14-2011, 05:26 AM   #583
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
The shine is looking great, it would be nice sometimes if life would just be more understanding of our projects!
Doug
It's not worth doing if you're not having fun.
https://tinman54.blogspot.com/
https://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 05-14-2011, 07:59 AM   #584
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
Wow! So beautiful. What a shine!
Lisa
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
bolerama is offline   Reply With Quote
Old 05-19-2011, 07:17 AM   #585
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Originally Posted by wasagachris View Post
I had the shroud painted in as close a color to aluminium as possible and used a pinstripe in A/S blue.
Hey Chris,
I have my AC shroud off. The old white paint is bleeding off onto the side of the trailer when it rains and needs to be painted. I think a silver shroud blends in and minimalizes the size. I'm taking it to the paint shop today. Do you happen to have the paint chip number or color code? Thanks.
Lance
Lance M is offline   Reply With Quote
Old 05-19-2011, 07:34 AM   #586
x
XXXX , XXXX
Lance The shroud I used was a new one from our mutual "friend" in California. It is fiberglass and the original one was plastic. mine was so badly degraded that it fell apart during removal. Are you sure your's will stand up and last?
As to the paint color all I know is that it was some sort of Ford silver. I left it up to the body shop manager at my Ford dealer to find a silver color that was close to aluminium. I called the deler just now and the manager will get back to me.
The pinstripe was an off the shelf thing that looked close to the Ford tractor blue I used to repaint the letters. Ford tractor blue can be found at TSC (Tractor Supply Company). I think you have TSC stores down there.
wasagachris is offline   Reply With Quote
Old 05-19-2011, 07:55 AM   #587
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Chris. The shroud was replaced in August 2003 by a PO with a new $225 fiberglass unit from your friend's company. Appreciate the help, as always.
Lance
Old 05-19-2011, 09:28 AM   #588
x
XXXX , XXXX
Hey Lance I got a message from the body shop. The paint code was either Ford TS or Chrysler PS2. He can't remember which one he used and would need to see the parts to tell which one they did use. He did not document the code so can't tell me for sure.
Old 05-19-2011, 10:47 AM   #589
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Chris,
I just got back from the body shop. He had a bunch of paint chips. I selected Ford TL I believe. They are all so similar and look different in different light. It'll look much better than before. My shroud is a bit different than yours though. It doesn't have a trim strip. It is a great idea to paint it silver in my opinion.
Lance
Old 05-19-2011, 04:18 PM   #590
1973 25' Tradewind
Oh the constructor isn't going to be happy about a new line on 'the list' but he will love the idea! Thanks.
Old 05-19-2011, 04:34 PM   #591
Baltimore , Maryland
Not sure if you got your paint already, but PPG has a line of metallic paints hot rod paints. There is one called "deep aluminum" it is actually a clear paint with finely ground aluminum. The match is almost perfect because, well aluminum matches aluminum pretty well.
Old 05-19-2011, 05:09 PM   #592
x
XXXX , XXXX
Ann you can blame me for planting the idea in your head. i've got broad shoulders and can take it, that the the constructor won't be mad at you.
Frank great tip on the paint. Thanks.
Old 06-14-2011, 10:00 AM   #593
x
XXXX , XXXX
It's been a month since I posted any updates and I don't really have much more done. I had to pull the trailer out today so the door company can come and fix the already fixed door. It never worked right since they fixed it last time and completely quit on the weekend.
So I thought I snap a couple of shots of the never ending story on polishing. I'm about halfway down the roadside on the first pass. I've got a couple of weeks left to try and get some more done before I get too busy here. I'll have to carry on again in Sept. after the season slows down. If I'm lucky I'll get the first pass done before July rolls in.
That's about all I'll be doing this year is finishing the polishing, maybe I can get the awnings on before winter sets in. I'm not going to be working on it this winter after paying last years electric bills to heat the shop.
Name:	Polishing June 14 2011 001.jpg
ID:	132466   Click image for larger version
Name:	Polishing June 14 2011 002.jpg
Name:	Polishing June 14 2011 003.jpg
ID:	132468   Click image for larger version
Name:	Polishing June 14 2011 004.jpg
Old 06-15-2011, 02:53 AM   #594
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
Looking great Chris!
I have not gotten anything done in the last 2 weeks myself between work and family stuff. This week my 6 year old has her 1st dance recital.
Leaving Sunday with my 12 year olds Boyscout troop to spend a week in tents at Camp Thunder in Georgia (about an hour south of Atlanta)
Baseman is offline   Reply With Quote
Old 06-17-2011, 06:50 PM   #595
1973 25' Tradewind
Chris, That is incredible. Someone is going to want to buy that from you. Can't wait to see the trailer at Frank's.
Old 06-17-2011, 07:21 PM   #596
x
XXXX , XXXX
Thank's Brad and Anne.
Brad I hope you have a good time with the Scouts.
Anne after all the hours I have put into this one it would have to be a very large check before I sell it plus I have a soft spot for this one as it is my first A/S and was my home for several years. Unfortunately the Buddha Baby is going to be on hold until next year. Finances have forced me to wait till next season before getting Frank to start on it. Thankfully he is very understanding about the delay.
Old 06-17-2011, 08:36 PM   #597
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Awesome looking trailer, Chris.
Can you put a wood heater in the shop?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 06-22-2011, 06:22 AM   #598
Hey Chris, I thought I'd catch up on your progress. Like you, my summer has been way too busy and that puts the A/S on hold.
The last pictures you posted really show the difference dramatically. Great job!!
Hope you have a successful summer season. And hopefully the economy will begin to turn around some time soon.
Lew TAC #WI-6
Old 06-22-2011, 07:34 AM   #599
x
XXXX , XXXX
Daniel Insurance won't allow wood stoves.
Lew Those last pics only show the first pass done, once further passes are done it looks even better. The weather and fuel prices are having a marginal impact on business but the greatest difference is in expenses. My bank made an error with the first 5 yr mortgage and are correcting it with the second almost doubling the payments. The only good news is that the business will be paid for in five years. Electricity costs are steadily rising. They are about to change the way we are charged for electricity. It's called the "time of use" pricing plan. It was supposed to reduce the cost when first discussed but from looking at it now I expect a 25% increase in electricity costs. So it's going to be a lean year combining lower revenue with much larger expenses. I may end up eating cat food this winter. LOL.
Old 06-22-2011, 07:57 AM   #600
Registered User
2019 27' Globetrotter
1957 16' Bubble
1957 22' Flying Cloud
Hillsboro , Oregon
Images: 171
WOW!!! She looks beautiful - although hearing you say "you're first pass" made my arms ache .....brought back not-so-distant memories of my DeWalt polisher
monah is offline   Reply With Quote
1973 excella 500, 31', full monte, polish, remodel, shell off
Now the fun begins..... kingfisher24 On The Road... 10 01-30-2010 08:36 AM
And so it begins... cameront120 Full-Timing 11 07-09-2008 08:21 AM
1969 - And so it begins... badelson 1965-1969 Sovereign 21 11-16-2007 06:36 PM
And so it begins...... SwampBillies Repairing/Replacing Floor &/or Frame 54 09-16-2007 03:56 PM
And So It Begins! Ifihadtime Member Introductions 5 04-27-2007 09:47 PM
