Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella 500 > 1973-1974 Excella 500
View Poll Results: Guess the tongue weight
under 250 lbs 3 9.68%
250 to 275 lbs 1 3.23%
275 to 300 lbs 5 16.13%
300 to 325 lbs 9 29.03%
325 to 350lbs 2 6.45%
Over 350 lbs 11 35.48%
Voters: 31. You may not vote on this poll
Old 10-22-2010, 08:26 PM   #141
Ottawa , ON
Originally Posted by wasagachris View Post
I'm just waiting for a day without rain in order to move everything.
Well, good luck with that one. Here in Ottawa it looks like rain straight through till it snows! LOL!
there is one other problem the workshop is a few inches too short to close the door so the only thing I would gain is dry but not warm. Once the real snow flies I need to put the backhoe into the shop to use it as a snow plow. Every task here is plus size. I pick up leaves with a dump truck and plow snow with a backhoe etc etc.
So get the backhoe, and dig the floor of the shop down a couple of feet, and then leave the dang backhoe out in the snow where it belongs. Chris, you got your priorities all wrong!
Old 10-22-2010, 09:00 PM   #142
x
XXXX , XXXX
Aage the building is not long enough front to back(30 ft building and 31 ft trailer). It's plenty high. The hoe needs to be in the shop to be plugged in or it won't start and if I leave it where it is now I won't be able to plow myself out let alone clear the roads.
wasagachris is offline   Reply With Quote
Old 10-22-2010, 09:03 PM   #143
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Be nice Doug Wabiteer has some valid concerns. Actually after spending the last few days in between rains rolling around under the trailer through puddles with it drippping all over me I could use a little hot weather.
It's taking a lot longer than I thought. I have insulated the entire centre section between the frame rails and started on the roadside section outside of the rails. Today was the worst with the melting snow constantly dripping in my face as I measured and attached the styrofoam strapping. I finally gave up at 5:30PM when the next round of rain got too heavy.
I know it gets hot in an Airstream, in the summer, I have one without an A/C. I'm just saying not today!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 10-22-2010, 09:33 PM   #144
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Chris, cut a hole in the back of the garage and pull the trailer in with a winch. Make the hole just enough to clear the tounge. That way you can heat it for working. It's not so strange, thats how I get my 28' in for working.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Old 10-23-2010, 05:19 PM   #145
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
WC, could you build a temp frame and enclose the door with plastic while you work on the AS? Or even a temp plywood door.
Chris
Old 10-23-2010, 05:59 PM   #146
x
XXXX , XXXX
Doug and Chris the big problem is that I need the building for the backhoe during the winter for plowing. I spent some time today emptying the trailer guts into another building. Once I have everything out I can at least put the trailer in out of the rain and almost close the door to work on it. As long as I can get it watertight this year I wuill start on the interior next spring.
Old 10-23-2010, 06:28 PM   #147
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
No, we all want you to take all the interior pieces out and put in the other building, then put the trailer inside, seal the door with tarp or whatever else you may choose. It was voted on and decided that you should put your backhoe in a new makeshift building you are to construct right away!
Ok, now get to work and send in more pics!
GREENovaters is offline   Reply With Quote
Old 10-23-2010, 06:31 PM   #148
x
XXXX , XXXX
Don`t I get a vote. LMAO. After all this is a democracy isn`t it. LOL
Old 10-23-2010, 06:42 PM   #149
Wabbiteer's Avatar
Jupiter , Florida
Wasagachris - My best guess is a warehouse area large enough for four trailers would be optimum to keep items & liners etc. arrayed in accessible heaps... Oh, and have the trailer under that same roof and I'd be deliriously happy.
Running out of storage is where my project stalled until I decided the entire interior was forfeit save for the sliding door bulkhead and some other bits. I bought a $1500 wrecked parts trailer to retain the option returning it to stock and cherry picking items better than on the project trailer.
Then came the $250 10' X 20' tent shelter ($850 as pictured) to have as a staging area to juggle parts through and store on liner panels, etc. in. If anyone goes toward an instant shelter like this one spend more upfront, they are kinda like Airstreams...
Oh - and don't give up the plow space for nothing. Thats one tool in its proper place!
ID:	113817   Click image for larger version
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 10-23-2010, 07:37 PM   #150
x
XXXX , XXXX
I absolutely love how much fun everybody is having with this issue. If you all want to see me continue through the winter I suggest you hitch up your trailers and head on up here and pitch in. Many hands make light work. I`ve got plenty of campsites available.
Wabbiteer I have one of those shelters but I doubt it would stand up to the snow load here. Even the metal garden sheds can`t take the weight. I`ve had at least three campers loose their sheds because they buckled under the snow. A few have had their decks collapse as well.
I agree that a warehouse big enough to hold 4 trailers would be fantastic. However there is nothing that large around here and how much can it cost to rent.
Here is a few pictures to show you what I mean.
ID:	113840   Click image for larger version
ID:	113842   Click image for larger version
Old 10-23-2010, 09:10 PM   #151
1973 31' Excella 500
Spring Green , Wisconsin
Chris, It is that time of year. The bright side is that we can all sit back and reread all the posts in this and other threads. And, plan for next spring....
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 10-24-2010, 08:16 AM   #152
moparjohn's Avatar
1973 25' Tradewind
Bloomsbury , New Jersey
Now I remember, the only thing I like about winter is the snow (HATE the cold) I can honsetly say I'll be spending the winter waiting for spring, as I haven't gotten out with the AS yet. I hope to get in at least a weekend trip in early Nov. maybe Maryland or upper Virginia. MPJ
Chris, love this thread.
moparjohn is offline   Reply With Quote
Old 10-24-2010, 09:54 AM   #153
Minno's Avatar
1972 31' Sovereign
Near as I can see, it's 3 to 2 (counting your vote) for moving the plow and modifying your building to house the airstream so you can work on it. I mean really, if the plow doesn't start, then you're simply stuck at home with more time to devote to your trailer. What's the probrlem here???
Old 10-24-2010, 10:40 AM   #154
x
XXXX , XXXX
Mc how about starvation from not being able to get out for food.
I`ll have an update for y`all in a couple of minutes. Please stand by.
Old 10-24-2010, 11:00 AM   #155
x
XXXX , XXXX
Smile Well i hope your happy now!
Since I didn`t hear from any volunteers. I have emptied the shop of the insides of the trailer into the rec center. The trailer is now inside high and dry. The back bumper is right against the back wall with a piece of cardboard to protect the bumper. As you can see form the pics almost only counts in horseshoes and hand grenades.
When I first moved here 5 yrs ago I tried to fit it in and I thought that the door would close if I cut away a section of the brace on the inside. Well either the building shrunk or the trailer grew (maybe I was wrong in the first place) because it just won`t fit.
Anyway it`s a good thing I haven`t burned the old floor yet because it came in handy. This will keep out the cold and rain as well as the 2 adopted cats I have living here. Everytime I turn around one of them is trying to get into one building or the other. 2yrs ago I accidently trapped another stray in the rec center for a week. He got in as I was storing things away for the winter and it wasn`t till a week later that I heard him calling to get out.
Anyway once the trailer dries out I can start the final foil insulation around the shell between the shell and the main frame rails. Then finally the belly goes on. Baby steps,baby steps.
ID:	113894   Click image for larger version
Name:	sooo close.jpg
ID:	113896   Click image for larger version
Name:	good use for old floor.jpg
Name:	trailer inside out.jpg
ID:	113898   Click image for larger version
Name:	high and dry.jpg
Name:	high and dry 2.jpg
ID:	113900   Click image for larger version
Name:	2011 project.jpg
Old 10-24-2010, 11:26 AM   #156
Minno's Avatar
1972 31' Sovereign
Aw man - that is sooooo dang close!!! Kinda late now, but if you took the rear bumper off the frame, would you gain the 1 1/2" it looks like you needed? Anyway, now I'm really jealous that you have a spot you can continue to work on her. I'm sitting here waiting til spring... But we need to buy things to continue on her now, and money is a tad tight with other stuff we have going on. House project will keep me busy over the winter. Starting with cleaning up my shop this afternoon so I can work on other projects.
Old 10-24-2010, 11:37 AM   #157
x
XXXX , XXXX
Mc I thought of that but no. Anyway I need the bumper on for the belly pan install. It attaches to the bottom of the bumper just inside the bottom lip of the bumper. That`s what forms the stinky hose compartment.
Old 10-24-2010, 04:50 PM   #158
Ottawa , ON
Well you sure have got me jealous now, Chris! I mean, I don't even have a garage here, and there's you with your TV AND your TT inside and all snug and warm for the winter while you work on the trailer.
I think we have just had our expectations raised a notch or two for seeing a beeYOOteeful interior all done come spring!
Old 10-26-2010, 06:39 PM   #159
x
XXXX , XXXX
First of all I need to catch up on afew posts.
MPJ thanks for the praise.
Aage don`t get your hopes up the trailer comes back out as soon as the belly is on and the shell is watertight. Then the backhoe goes in for the winter.
Well it took a while but all of the road(street, port, left) side of the trailer is insulated. I also got half of the curbside done. I should finish the other half tomorrow. The insulation installs easily but taping and sealing takes forever. There are so many seams and edges around each outrigger to seal.
Then I will begin cutting the belly pan. I will need 3 pieces. The first goes from the fresh water tank forward, the 2nd is between the A frame and is mounted directly to the floor to make space for the spare tire. The last piece and the longest goes from the back of the fresh water tank to the bumper. We plan to install the belly this weekend.
Name:	Insulation Pt 2 001.jpg
ID:	114088   Click image for larger version
Name:	Insulation Pt 2 002.jpg
Name:	Insulation Pt 2 003.jpg
ID:	114090   Click image for larger version
Name:	Insulation Pt 2 004.jpg
Old 10-26-2010, 09:46 PM   #160
Ottawa , ON
OK, I get it now, Chris. Well, at least you'll be able to wax the backhoe.
The underside of your trailer is starting to look like a wrapped xmas gift! Beautiful.
1973 excella 500, 31', full monte, polish, remodel, shell off
Now the fun begins..... kingfisher24 On The Road... 10 01-30-2010 08:36 AM
And so it begins... cameront120 Full-Timing 11 07-09-2008 08:21 AM
1969 - And so it begins... badelson 1965-1969 Sovereign 21 11-16-2007 06:36 PM
And so it begins...... SwampBillies Repairing/Replacing Floor &/or Frame 54 09-16-2007 03:56 PM
And So It Begins! Ifihadtime Member Introductions 5 04-27-2007 09:47 PM
