View Poll Results: Guess the tongue weight
under 250 lbs 3 9.68%
250 to 275 lbs 1 3.23%
275 to 300 lbs 5 16.13%
300 to 325 lbs 9 29.03%
325 to 350lbs 2 6.45%
Over 350 lbs 11 35.48%
Voters: 31. You may not vote on this poll
Old 10-11-2011, 07:50 PM   #631
x
XXXX , XXXX
Riddle of the day!
So how exactly do you fit the entire interior of a 31ft Excella into a 26 ft Overlander?
Very carefully!
Today I needed to make room in my shop for a vintage tow vehicle that I recently purchased. I was at a loss as what to do with the contents of my 1973 Excella that is still an empty shell. I have been stalled on the polishing stage this summer as I can't get that dirty and still run my business. Now that I'm closing for the season I will be able to get back on the polishing wagon after I return from my multiple recovery missions.
Anyway back to the matter at hand. What do you do with half a buildings worth of parts? Well I have this 63 O'lander sitting here as a parts trailer. Perfect solution. I now have a rolling Airstream shed.
Name:	Fitting a 31 into a 26 001.jpg
ID:	142423   Click image for larger version
Name:	Fitting a 31 into a 26 002.jpg
Name:	Fitting a 31 into a 26 003.jpg
wasagachris is offline   Reply With Quote
Old 10-11-2011, 08:29 PM   #632
Airstream Fanatic
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck , North Dakota
Glad to know
Very carefully!
I can't say we have a rolling AS shed but we do have piles in two different garage stalls of the guts of the Sovereign. I am getting tired of trying to get around them and now we have added my 94 year old mother in law's excess stuff from her going into assisted living. It looks like we are either moving out or in depending upon the angle you look at it. Kind of crazy to have this much stuff. Some days I think it would be simpler to just lock the door and drive away....
I might tell my better half that we need to get another AS so we can use it for a rolling AS shed. Might be a lot cheaper than putting up a building was last year to hold our current AS. I'm still working on him to agree to another AS.....keep your fingers crossed that you get to see a new one when you stop in.
I'll make sure to bring that new old AS subject up when he is not holding any kind of a tool in his hands.
Sandy
ND10CentCan is offline   Reply With Quote
Old 10-12-2011, 02:58 AM   #633
Baltimore , Maryland
I think there is still room to cook meth in there...
Old 10-12-2011, 11:56 AM   #634
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Ah. I was wondering what kind of chemicals those drums in the pictures were filled with.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 10-14-2011, 12:58 AM   #635
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
Looks like the inside of my shop! We still have the entire interior of the Tradewind in there.
Baseman is offline   Reply With Quote
Old 10-16-2011, 06:23 PM   #636
x
XXXX , XXXX
New Use For Old Axles
Tonight the guy who welded my frame finally took the old axles home. He is going to use them to make a utility/car hauler trailer. When we finished making the new frame the old one was cut up and scraped. We kept a small portion of the frame holding the axle mounting plates and left the old axles attached.
This is how he transported them home.
Name:	New use for old axles 001.jpg
Name:	New use for old axles 002.jpg
Necessity is surely the mother of invention in this case.
Old 10-16-2011, 06:30 PM   #637
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
I'm not an expert, but I belive those axles need a new Airstream! LOL! MPJ
moparjohn is offline   Reply With Quote
Old 10-16-2011, 08:41 PM   #638
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Should have left the black tank in and toilet + seatbelt... Would have been refreshing
Darkspeed is offline   Reply With Quote
Old 10-17-2011, 02:58 AM   #639
Are those Maxi's your running on?
Old 10-17-2011, 03:20 AM   #640
Flying Cloud STEVE
2010 25' FB Flying Cloud
Carrollton , Texas
I'm a newbie and understand your problem. I don't think I caught what was the initial cause of this leak, some canister storing water cracked?? Any lessons learned that might help others prevent this same thing happening five or ten years down the line?
Flying-Steve is offline   Reply With Quote
Old 10-17-2011, 04:55 AM   #641
x
XXXX , XXXX
Steve there are numerous sources for leaks to occur in any Airtsream just like any other trailer. Basically any point that has a hole in the shell, windows, vents, attachments etc can cause leaks if not properly maintained.
The most prolific source of leaks is the rear bumper cover or storage door. The horizontal mounting plate that the door is attached to actually acts like a trough funnelling water back against the body(shell). If this area is not properly sealed water will penetrate the shell and be absorbed by the wood subfloor. If left unchecked long enough the insulation in the belly pan becomes saturated and retains all this moisture against the bottom of the sub floor causing the wood to rot. It will also cause premature rusting out of the frame crossmembers etc.
Old 11-22-2011, 07:32 PM   #642
x
XXXX , XXXX
Polishing again
It's been an etremely long time since I've posted to this thread. as you may know I'm in the polishing stage of the renovation. I had to stop earlier this spring because I just couldn't get that dirty and still be available to fun my business. Now that I'm closed for the season and have finished all the work involved with shutting down I can finally start polishing again. OH JOY.
Yesterday and today I spent about 6 hrs a day and got about 10 lineal feet of the roadside shell polished with the first pass. The weather is supposed to be reasonable this weekend so I plan to pull the trailer out of it's hole in the wall (literally) and get the rear end cap and the back of the trailer polished.
With any luck I will have all of the first pass done on the roadside before then.
I didn't bother to take any pics as they seem boring to take.
Old 11-22-2011, 07:52 PM   #643
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Back in the saddle again....
Good to hear you are back in the polishing mode again. Any new purchases of AS or recovery missions in sight?
Sandy
Old 11-22-2011, 08:00 PM   #644
x
XXXX , XXXX
Hi Sandy no new A/S purchases but I will be going down to Baltimore soon to get the liner once it is titled. I need to register it here but can't without a title.
I did have a message waiting for me when I got home. It was a guy with a 68 Overlander and somehow he heard that I buy Airstreams. I was tempted but he wants too much for it. I actually convinced him to keep it. He wanted to sell it and get a bigger white box unit.Besides I'm running out of space to park any more trailers. LOL
1973 excella 500, 31', full monte, polish, remodel, shell off
Now the fun begins..... kingfisher24 On The Road... 10 01-30-2010 08:36 AM
And so it begins... cameront120 Full-Timing 11 07-09-2008 08:21 AM
1969 - And so it begins... badelson 1965-1969 Sovereign 21 11-16-2007 06:36 PM
And so it begins...... SwampBillies Repairing/Replacing Floor &/or Frame 54 09-16-2007 03:56 PM
And So It Begins! Ifihadtime Member Introductions 5 04-27-2007 09:47 PM
