View Poll Results: Guess the tongue weight
under 250 lbs 3 9.68%
250 to 275 lbs 1 3.23%
275 to 300 lbs 5 16.13%
300 to 325 lbs 9 29.03%
325 to 350lbs 2 6.45%
Over 350 lbs 11 35.48%
Voters: 31. You may not vote on this poll
Old 12-18-2010, 09:24 PM   #253
x
XXXX , XXXX
Power & water reel access door
Aage you can see the access door in this shot I took before I started the reno. BTW what happened to Ned? I miss the new Ned avitars.
wasagachris is offline   Reply With Quote
Old 12-18-2010, 09:29 PM   #254
Ottawa , ON
OK, it's the square-cornered door? Gotta admit, first time I see that kind of door. You sure it isn't and after-market feature, the reel? Or is it mentioned in your manual..?
Yes, I change my avatar fairly frequently, and had temporarily run out of Neds.
Old 12-18-2010, 09:36 PM   #255
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
My Excella does not have that door. I have something on the curb side in a similar place and a similar size that I cant figure out what it is/was. A previous owner covered the hole with a piece of tin, but on the inside you can see that something was riveted on there at one time. Any idea?
DanielB is offline   Reply With Quote
Old 12-18-2010, 10:18 PM   #256
x
XXXX , XXXX
Aage airstream lists it a standard equipment on excella's. It looks factory built because of the interior cover for it under the bed.
Daniel the 74 is listed as having the same option. I don't know why it would be curbside though. My 73 manual shows the center bath plan having the bath on the roadside. Daniel is your bath curb or road side?
Old 12-18-2010, 11:05 PM   #257
Ottawa , ON
Well, you learn something new every day! Thanks, Chris.
Old 12-19-2010, 12:57 AM   #258
1973 31' Excella 500
Spring Green , Wisconsin
Our '73 Excella has the same door for the water hose and electric line and our manual shows the reels as standard equipment for the Excella. You can see the white hose coming out of it. We don't have the square door that is further to the front like yours though. Is that your water heater?
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 12-19-2010, 06:56 AM   #259
x
XXXX , XXXX
Lew the larger square door that you are talking about is the ONAN propane fired 12VDC generator. It was an option available during the 70's. Mine had never worked and when I finally tried to get it repaired the parts I needed were no longer available. I bought another one that is in good shape from a forum member. It fired right up and after replacing a couple of fuses it is nowa working generator. Like I said it is propane fired and generates 12VDC and 300 watts. It's basically a huge battery charger.
Old 12-19-2010, 07:22 AM   #260
DanielB's Avatar
I don't have that door that opens downward, but I am missing the belly pan and everything in that area. Maybe it used to be there? The first pic is roadside rear (the images are negative reversed). The second pic is curbside rear where the mystery hole is withe the piece of tin covering it.
ID:	117281   Click image for larger version
Old 12-19-2010, 08:34 AM   #261
x
XXXX , XXXX
Daniel You probably had the reels and the PO removed them. The door is in the belly pan side wrap. There is a piece of plywood sitting on 2 outriggers that the reels sit on. Did you find the last 2 outriggers on the road side that had a small piece of angle iron welded to them. That is what the plywood sits on. The floor is cut out in that area. There is a plastic shroud that cover everything from the inside. the whole assembly sits under the bed. The other hole that the PO covered with tin is the hole for the water heater.
Old 12-21-2010, 01:39 PM   #262
x
XXXX , XXXX
New Lights
I got a small order in yesterday from LED`S4RVS. I put in the pad LED for the over the door light(porch light). It attaches quite easily and at the same time I replaced the original socket with a new one. I also installed the new light lens from INLAND RV. It didn`t fit quite right just like the original so I spent some time last night filing and sanding the edges to get it to fit tighter into the housing. Today I installed the whole assembly and also installed the new scare light. On my old one the chrome housing was very pitted so I ordered the complete unit. The new one comes with only three mounting holes and the old one had six so I drilled out the other three ones, applied butyl tape to the new housing and installed it with new stainless steel screws. The screws don`t pull the light in tight to the shell so I intend to replace them with stainless machine screws and nylon lock nuts.
I`m still waiting for the local shop to fabricate the hew fan guard for the air conditioner fan. The guard goes above the shroud on the roof. They are also fabricating a removeable screen and frame. This screen will keep all the tree droppings etc. from filling up the shroud again. The parts may be ready on Thursday and I will try to get the shroud installed over the weekend.
Name:	New LED Scare & Porch Light 001.jpg
ID:	117473   Click image for larger version
Name:	New LED Scare & Porch Light 003.jpg
Old 12-21-2010, 01:59 PM   #263
Ottawa , ON
Hi, Chris.
So, does this make the cover non-removable? Or am I not getting something (again)?
I suppose it doesn't matter since the LED lights are good for a l-o-n-g while, right?
Old 12-21-2010, 02:12 PM   #264
x
XXXX , XXXX
Aage it is the chrome housing that is not sitting in as tight as I would like it. The butyl tape is a little bit thicker than the original two sided foam tape. I would like to pull the housing in tighter to the shell to compress the butyl and completely seal the housing. I will of course seal it inside with vulkem and seal the outside edge with parbond. All part of my triple or quardruple method of sealing up openings. The lens is still removable and it has it`s own felt gasket to seal it. I do plan to replace the stupid phillips screws holding the lens with again stainless machine screws with the better Robertson heads.
BTW both lights come with the warning not to leave them on during the day as the heat of the LED and sunshine plus daytime temps will cause premature failure of the LED. So I guess they don`t last forever.
I had a conversation with Dan at LED`S4RVS yesterday. We talked about interior lights. he has a 42 LED pad for the ceiling fixtures which give off 1042 lumens (equivalent to 100 Watt incandescant) and only uses 133 milliamps of power comared to the original 10 watt bulb that uses 1.2 amps. That is amazing 10 times the light for about one tenth the power consumption. They are however 20 times the price of the original bulbs.
Old 12-21-2010, 02:22 PM   #265
Ottawa , ON
OK, I have never taken my scare light apart (it's one of the few lights that worked from when I bought the TT) so didn't know the lens would come off without removing the chrome ring.
That's scary, but good to know. It's pretty bright anyways, so I really don't use it much.
I was thinking of putting those strips of LEDs in the existing fixture, but I was hoping they would come down in price a bit more. I know the payback vs. cost won't happen in my lifetime, but when I bought Henri, I replaced ALL the bulbs in ALL the fixtures, and it cost a bundle. I want to get SOME use from them, I don't see anyone wanting to buy a bunch of used ones...
Old 12-21-2010, 03:14 PM   #266
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
12 volt generator?
It runs on propane, how is it vented? I see a bottom vent, but what about risk of exhaust within the trailer?
Is it vented like a water heater would be? How long did it take to bring the battery up to proper charge? Would you run it constantly, or intermittently?
I'm thinking that would no longer be available as an option (?).
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
1973 excella 500, 31', full monte, polish, remodel, shell off
Now the fun begins..... kingfisher24 On The Road... 10 01-30-2010 09:36 AM
And so it begins... cameront120 Full-Timing 11 07-09-2008 09:21 AM
1969 - And so it begins... badelson 1965-1969 Sovereign 21 11-16-2007 07:36 PM
And so it begins...... SwampBillies Repairing/Replacing Floor &/or Frame 54 09-16-2007 04:56 PM
And So It Begins! Ifihadtime Member Introductions 5 04-27-2007 10:47 PM
