Old 12-18-2010, 09:58 AM   #29
Ottawa , ON
So? Where are the photos!!?
Old 12-18-2010, 02:23 PM   #30
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I am disappointed. Heard nothing from the guy this morning then he emails me around noon says it will be monday. Bummer. Can't get upset about someone taking longer than they thought that they would. Still a bummer.
DanielB is offline   Reply With Quote
Old 12-18-2010, 07:59 PM   #31
Ottawa , ON
Yeah, I know what you mean, Daniel. Well, if he stiffs you again, give him similar treatment regarding payment. That might make him think twice about doing that again...
Old 12-20-2010, 06:38 PM   #32
DanielB's Avatar
Trailer delivered. Too dark for pictures. Will post some in the morning. I'm stoked!
Old 12-21-2010, 05:31 AM   #33
DanielB's Avatar
New chassis
Delivered last night..
From the looks of it the C5x6.7 C Channel is perfect. Thicker than the original, but not too thick.
The fabricator said that the steel in the chassis is 1000 lbs (not including axles or tongue).
ID:	117433   Click image for larger version
ID:	117435   Click image for larger version
Old 12-21-2010, 06:08 AM   #34
x
XXXX , XXXX
Loookin goood Daniel The pics are still bass ackwards right. Are you getting new axles. Now would be the time to put them on. POR-15 now right.
wasagachris is offline   Reply With Quote
Old 12-21-2010, 01:08 PM   #35
Ottawa , ON
Lookin' good! Big step there, huh? Way to go!
Chris: I give up: how can you tell his photos are backwards?
Old 12-21-2010, 01:20 PM   #36
x
XXXX , XXXX
Aage intimite knowledge of the 31 ft frame.
Actually all his pics are reversed. Some weird quirk with the camera or his pic program. Look back at the first pics you will see the entry door on the roadside. It really looks odd because it looks like the trailer is supposed to be that way. It`s only when you see the pics of the front and it says MAERTSRIA on did I clue in.
Old 12-21-2010, 01:25 PM   #37
Ottawa , ON
LOL! OK, I get it now... Yeah, some of his pics have big hints, like Airstream backwards, but I couldn't see what you did in those frame shots...!
Is the attached one better?
Old 12-21-2010, 01:27 PM   #38
x
XXXX , XXXX
It was intimate knowledge I was counting outriggers and the numbers didn`t match the side.
It must be an optical delusion
Old 12-21-2010, 01:30 PM   #39
Ottawa , ON
Or it just looks like one
Old 12-21-2010, 01:48 PM   #40
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Note to self: this frame has much more sturdy crossmembers than original, and the frame will in particular resist twisting far better then the old frame.
When I make my frame I can delete at least four of them, and redistribute them for better rigidity and flex performance while reducing weight by 200 lbs or so. Also, place an inverted L section on the frame rear to provide better shell to frame contact area, so it will never EVER have rear end separation.
This concludes my note to self.
TX-16
Dave Park is offline   Reply With Quote
Old 12-21-2010, 06:19 PM   #41
DanielB's Avatar
Thanks for the encouragement. Bid deal here.. Three tough jobs.. lifting the shell, getting new chassis, replacing shell.. 2 of the 3 are done. One more to go..
Yeah the pictures are negative reversed. I need to doctor them before I post them because they weird me out.
The cross members are generally 2' on center.. and those support the subfloor too. If you remove them won't that take away support for the floor?
Old 12-21-2010, 06:31 PM   #42
DanielB's Avatar
I could barely contain my excitement today. I had to go by the auto parts store and pick up some rust proofing stuff. They used to sell POR 15 but now only sell KBS ( Stop Rust - Gas Tank Sealer - Gas Tank Liner - KBS Coatings - RustSeal in Colors ). I got some. Cleaner, etcher, and sealer.
What a relief to have the chassis back.
The cold spell that blew down from the Great White North has passed. It should be up in the upper 50s through the weekend. If it doesn't rain (any more), I should have the chassis sealed up by the end of the week.
I still haven't decided what to use for the floor. I'm leaning toward 3/4 plywood, but still don't have the warm and fuzzies that it can be sealed well enough to out live me (and maybe a while for the boy.. who is 18.. and who's grand plan for the interior is 1) 60" plasma tv 2) Couch 3) Bed. "That's all you need" he says).
1974 excella, axle
Shower wall rebuild Joebanjo Sinks, Showers & Toilets 9 03-03-2013 11:09 AM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
The "95" Question monkeypants On The Road... 2 03-28-2012 05:11 PM
Started the Clean and Wax routine today. Bruce B Clearcoat, Exterior Paint & Trim 12 03-20-2012 08:32 AM
so .... afixin to put in a new ac Orlop All Argosy Trailers 2 03-19-2012 05:55 PM
