Old 12-14-2010, 10:01 PM   #21
Ottawa , ON
Daniel,
your Service Manual gives charts that show the physical positions of all the systems: drains on one page (with heating, IIRC), plumbing on another, and so on. Or don't the diagrams apply to your model at all?
Old 12-15-2010, 02:43 AM   #22
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I didn't see this mentioned...but gas lines go on the outside after the belly pan is on. They have individual shutoffs valves then the line goes through the belly pan to the individual appliance. On my unit they are all copper, a couple of different sizes depending on what appliance they are going to.
Everything else is run above floor. I will see if I can post a few pictures later today, heading out the door to work.
Aaron
WBCCI #XXXX AIR #2495
Old 12-15-2010, 05:02 AM   #23
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Originally Posted by Aage View Post
Daniel,
Yes the diagrams are in the service manual, but they don't show what goes above the floor and beneath the floor.. not that I can decipher. I'll look again.
DanielB is offline   Reply With Quote
Old 12-15-2010, 05:05 AM   #24
DanielB's Avatar
Aaron
That would make some sense.. don't have to protect against freezing and would definately want to have direct access to gas lines if possible. Thanks.
Old 12-15-2010, 05:12 AM   #25
DanielB's Avatar
Originally Posted by Dave Park View Post
Nowadays, the factory lays a full roll of reflectix bubble foil down on the frame before laying down the wood - this seems like a really smart idea, but I still prefer the idea of the floor directly contacting the frame.
I'm seriously considering (pending some research) using a radiant barrier in the walls as well.
Old 12-15-2010, 06:06 AM   #26
x
XXXX , XXXX
Daniel I`ve got your 6. Here is a link to the insulation that is the best with great prices. It doesn`t absorb water and is not bubble wrap. Bubble wrap could possibly with enough heat have the bubbles pop from expansion of the air in the bubbles. The roll I bought was large enough to put two layers in the belly and I have half the roll left to do the interior. i will probably need more.
Insulation for Less : Prodex : Reflective Insulation : Pole Barn Insulation : Metal Building Insulation : Bubble Insulation
wasagachris is offline   Reply With Quote
Old 12-15-2010, 06:10 AM   #27
DanielB's Avatar
Awesome. Thanks.
Old 12-17-2010, 08:08 PM   #28
DanielB's Avatar
I'm supposed to get my new chassis tomorrow. I'm all giddy like a girl..
Old 12-18-2010, 09:58 AM   #29
Ottawa , ON
So? Where are the photos!!?
Old 12-18-2010, 02:23 PM   #30
DanielB's Avatar
I am disappointed. Heard nothing from the guy this morning then he emails me around noon says it will be monday. Bummer. Can't get upset about someone taking longer than they thought that they would. Still a bummer.
Old 12-18-2010, 07:59 PM   #31
Ottawa , ON
Yeah, I know what you mean, Daniel. Well, if he stiffs you again, give him similar treatment regarding payment. That might make him think twice about doing that again...
Old 12-20-2010, 06:38 PM   #32
DanielB's Avatar
Trailer delivered. Too dark for pictures. Will post some in the morning. I'm stoked!
Old 12-21-2010, 05:31 AM   #33
DanielB's Avatar
New chassis
Delivered last night..
From the looks of it the C5x6.7 C Channel is perfect. Thicker than the original, but not too thick.
The fabricator said that the steel in the chassis is 1000 lbs (not including axles or tongue).
ID:	117433   Click image for larger version
ID:	117435   Click image for larger version
Old 12-21-2010, 06:08 AM   #34
x
XXXX , XXXX
Loookin goood Daniel The pics are still bass ackwards right. Are you getting new axles. Now would be the time to put them on. POR-15 now right.
Old 12-21-2010, 01:08 PM   #35
Ottawa , ON
Lookin' good! Big step there, huh? Way to go!
Chris: I give up: how can you tell his photos are backwards?
Old 12-21-2010, 01:20 PM   #36
x
XXXX , XXXX
Aage intimite knowledge of the 31 ft frame.
Actually all his pics are reversed. Some weird quirk with the camera or his pic program. Look back at the first pics you will see the entry door on the roadside. It really looks odd because it looks like the trailer is supposed to be that way. It`s only when you see the pics of the front and it says MAERTSRIA on did I clue in.
Old 12-21-2010, 01:25 PM   #37
Ottawa , ON
LOL! OK, I get it now... Yeah, some of his pics have big hints, like Airstream backwards, but I couldn't see what you did in those frame shots...!
Is the attached one better?
Old 12-21-2010, 01:27 PM   #38
x
XXXX , XXXX
It was intimate knowledge I was counting outriggers and the numbers didn`t match the side.
It must be an optical delusion
Old 12-21-2010, 01:30 PM   #39
Ottawa , ON
Or it just looks like one
Old 12-21-2010, 01:48 PM   #40
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Note to self: this frame has much more sturdy crossmembers than original, and the frame will in particular resist twisting far better then the old frame.
When I make my frame I can delete at least four of them, and redistribute them for better rigidity and flex performance while reducing weight by 200 lbs or so. Also, place an inverted L section on the frame rear to provide better shell to frame contact area, so it will never EVER have rear end separation.
This concludes my note to self.
TX-16
Dave Park is offline   Reply With Quote
1974 excella, axle
Shower wall rebuild Joebanjo Sinks, Showers & Toilets 9 03-03-2013 11:09 AM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
The "95" Question monkeypants On The Road... 2 03-28-2012 05:11 PM
Started the Clean and Wax routine today. Bruce B Clearcoat, Exterior Paint & Trim 12 03-20-2012 08:32 AM
so .... afixin to put in a new ac Orlop All Argosy Trailers 2 03-19-2012 05:55 PM
