Old 03-04-2015, 09:37 AM   #29
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I always learn something from these discussions. I am a fan of diesels for towing, period. However, a while ago when people started to push the Tundra and it's abilities I did some research and by golly I learned something. I still would not buy one to tow our 30' FC as I need payload - I often have my,my wife, two 60 pound + dogs, two kayaks and a golf cart in the bed of the truck. Plus all the normal AS stuff.
So, the discussions in my opinion are great - if kept civil.
Thanks for this forum by the way - as stated I learn a lot.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-04-2015, 05:00 PM   #30
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That's why they make Fords and Chevys-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-04-2015, 05:01 PM   #31
m.hony's Avatar
2013 30' Classic
A Tundra won't (or shouldn't or can't) pull a 30 with a golf cart in the bed-
TAC #MS-10
Airforums #70955
Old 03-04-2015, 06:06 PM   #32
westcoastas's Avatar
2005 28' Safari
formerly of Tustin, Huntington Beach, Dana Point, and Laguna Beach , California
Beeswaxowl - I asked for some recommendations here too and I found a 2012 Tundra 5.7L with 4WD. Like someone advised previously, maybe it's not the vehicle to tow your AS (we pull about 7,000 lbs) but I wanted to make the case for 4WD on any truck if you're planning on doing some disperse camping on BLM land. We've been doing some scout trips on backroads and it's a bit comforting to know we have the 4WD. It doesn't get you out of every tough spot (as we found in sloppy clayey mud one rainy afternoon) but we feel we can check out more potential spots for dry camping this way. If you're good with RV parks and developed campgrounds, then 4WD is probably a waste of money. Good luck!
westcoastas is offline   Reply With Quote
Old 03-04-2015, 07:14 PM   #33
m.hony's Avatar
2013 30' Classic
I still recommend a Tundra, but not with an 800# Harley in the bed-
I am absolutely ecstatically happy with my rig.
TAC #MS-10
Airforums #70955
Old 03-09-2015, 08:24 PM   #34
2015 30' Flying Cloud
Westport , Connecticut
Want to buy one for me too? I'm considering the same TV! :-)
KiraR is offline   Reply With Quote
Old 03-10-2015, 12:36 PM   #35
m.hony's Avatar
2013 30' Classic
Buy you one what? With what money?
TAC #MS-10
Airforums #70955
Old 03-10-2015, 02:20 PM   #36
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Towing capacity as defined by the auto manufacturers (which really should be called pulling or dragging capacity) is not usually the major issue when selecting a tow vehicle, PAYLOAD capacity should be. Just about any half ton pickup truck will pull just about any Airstream including the heavier 34 footers and the ones with slides. Where you get into trouble is the cargo capacity of the tow vehicle once you add the REAL tongue weight of your Airstream and whatever else you put in the tow vehicle.
Half ton pickups usually have a payload capacity of between 1,300 lbs and 1,900 lbs. Some have more but those are usually "work trucks" with a cloth bench seat in the front, roll-up windows and a relatively short bed. I don't see too many Airstreams getting pulled by "work trucks." Most are pulled by fancier models with longer wheelbases and often a cap with God knows what inside. After you set aside 900 to 1,000 lbs for the tongue weight, which is a typical real world tongue weight for a packed-for-camping contemporary 25 to 30 Airstream, you can see where the math can quickly come up short.
So if you travel with basically an empty bed no problem. But if you put your 500 - 700 lbs. motorcycle or your rock collection in the bed and have a heavy cap to boot, then watch out.
If you are a casual camper (which means you probably have a job, spouse, 2.1 children and 1.25 dogs) and only go away for weekends and the proverbial two to three weeks of vacation relatively close to home, then a smaller less capable tow vehicle is fine. On the other hand, if you spend most of your life on the road and drag a lot of your worldly possessions with you, a larger tow vehicle will be very much appreciated.
Of course, WHATEVER tow vehicle you have you should use a properly set up weight distributing/anti sway hitch.
When in doubt, go big, or go home!
Bob Martel
WBCCI# 5766
Old 03-10-2015, 03:01 PM   #37
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
I've got a friend who has the very same Airstream. He got it from his dad last year. He is new to this as well and has a late model 1/2 ton GMC. It pulled it but that's about it. We hooked up my 2015 F250 diesel to it and I gave him the keys. He said it was like night and day. If your going to use it then get a TV your Comfortable with and that can do the job. That's one heavy trailer. Pay me now or pay me later. Good luck
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 03-11-2015, 06:40 AM   #38
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Or one of these....
NavyCorpsman is offline   Reply With Quote
Old 03-13-2016, 07:16 AM   #39
1997 30' Excella
Winnipeg , Manitoba
I know this thread is dead... But I just wanted to add that I ended up going with a 2015 Tundra. I am pretty sure I will be really happy with this truck.
Beeswaxowl is offline   Reply With Quote
Old 03-13-2016, 07:39 AM   #40
m.hony's Avatar
2013 30' Classic
Yes, you will.
Does your new Tundra have the larger fuel tank, integrated trailer brake controller, and ability to adjust headlights down under load to prevent blinding oncoming cars at night?
TAC #MS-10
Airforums #70955
Old 03-13-2016, 09:25 AM   #41
jump's Avatar
2013 30' International
lubbock , Texas
Ok, Beeswax, let's see those pics of your TV & AS together
jump is offline   Reply With Quote
Old 03-14-2016, 10:29 AM   #42
2014 23' Flying Cloud
Rhinebeck , New York
Just wanted to say "I liked this thread," and learned quite a bit. Thanks to all.
Adam
Adam Geuss is offline   Reply With Quote
Should I buy or should I run away ddruker Ribs, Skins & Rivets 16 04-15-2012 10:35 AM
new owner of excella 34', what tow vehicle should I buy? 123f5 Tow Vehicles 11 09-05-2010 09:47 PM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
Should we or should we not Angel73 Floor Finishes 12 03-18-2007 08:48 PM
1980 Airstream Land Yacht - Should we buy? cbird01 Airstream Motorhome Forums 0 08-03-2002 09:06 AM
