Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1997 -2001 Excella
Old 10-18-2012, 11:02 AM   #1
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
Wet floor around door opening. Have questions.
okay, I have done a rudimentary search for gen'l info on this-no luck. my 2000 was/is wet right at the entry; we had the airstream rug at the door all weekend. It was a wet weekend, but I cannot determine where the water has come from any experience with this phenom? Thanks in advance
bill
wmarsha is offline   Reply With Quote
Old 10-18-2012, 11:13 AM   #2
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Phenomenal Experience with this Phenomenon
Always remember, where the H2O pools may not tell you where it entered.
There are several entry points through the exterior skin, that allow the H2O to run down the inside of the interior skin to the floor in front of the door.
I once devoted much time and energy to replacing the door gasket (rarely the culprit and didn't fix my leak).
Start at the uppermost hole through your exterior skin and work downward toward the door.
Most of my H2O penetration was coming through seam around the top vent, running down the inside of the interior skin and pooling on the floor at the door.
Some H2O was penetrating the window adjacent to the door and adding to the pool.
Remember also: NEVER USE SILICONE CAULK. The one sin the Airstream gods cannot forgive.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Greetings and hello with questions rodsterinfl Member Introductions 36 02-24-2012 03:02 PM
Newbie/lurker first post with questions airfun Member Introductions 14 02-07-2012 02:39 PM
Noob with tons of questions! 8string Full-Timing 14 07-20-2011 12:55 AM
'73 TW Wet Bath Floor issues my3sonsdad Repairing/Replacing Floor &/or Frame 1 07-01-2011 12:40 PM
Wet bath to shower? osolow Sinks, Showers & Toilets 6 03-24-2011 10:25 AM
