Old 11-26-2013, 07:22 PM   #1
1990 29' Excella
South Miami , Florida
Sofa on 1999 Excella
We are finishing the remolding on our 1999 30" Excella and have a question I need somebody to help me with!
On the Original sofa, the backrest folds over and becomes a full size bed. Once it is extended, where does it rest on to support the weight?
I assume I have to slide out the bottom section and let it rest on there, but want to be sure if I'm doing it the right way?
George B.
South Miami, Fla
J&G22argosy is offline   Reply With Quote
Old 11-26-2013, 07:40 PM   #2
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
My gaucho balances on the frame, no visible support from anything. It is the most uncomfortable sleep you will have, IMO, unless you are going to replace the foam. Good luck!
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 11-26-2013, 08:09 PM   #3
bganso's Avatar
1994 30' Excella
Truckee , California
Ours flips over also and is supported by the frame, but we pull out the drawer for support. Don't know how comfortable it is as I've only experienced 'Martini Naps'
bganso is offline   Reply With Quote
Old 11-27-2013, 09:12 AM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Our '99 front sofa flattens by lifting the front edge of the seat slightly and pulling out toward the rear of the coach. The OEM sofa was uncomfortable. When we had the interior textiles replaced at Arlene Fowler's this summer we also replaced the OEM with a newer model OEM. Much more comfortable when needed as a bed. B4 and After here: 2013 Airstream Interior Before and After - a set on Flickr
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 11-27-2013, 09:51 AM   #5
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
nice!
Originally Posted by Silver Otter View Post
... When we had the interior textiles replaced at Arlene Fowler's this summer we also replaced the OEM with a newer model OEM. Much more comfortable when needed as a bed. B4 and After here: 2013 Airstream Interior Before and After - a set on Flickr
Very nice!
