Old 03-24-2013, 10:35 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Mjolnir...problems
Looks like the name Mjolnir (Thor's hammer) name has stuck.. but, has been abbreviated to "Mo"... Mjölnir - Wikipedia, the free encyclopedia
So, here are problems today.. on Roof:
1- all plumbing vent caps cracked/leaking
2- all sealant around vents separating
3- sealant around antenna pulling away
4- skylights all cracked/hazed leaking... and appear to be wrong size for original openings.
5- white roof coating in good shape, but at seams, appear to be separating or worn down..
On windows:
1- front window tinted rock guards missing camlock screw and retainer
2- window seals barely pliable
3- front window tinted rock guard seals appear to let water in top and pool at bottom of window
On windows and door:
1- caulking around top of all windows and the door are pulling away from body of Mo...
2- Door gasket not very pliable
3- side window gaskets appear to be usable for a while
Rather than go off guessing what to do, I have in my hands a 'reseal kit' from Airstream... and will apply judiciously.. first, however, I would appreciate some input... how would you approach these tasks?
Thanks in advance...
Old 03-25-2013, 04:58 AM   #2
dznf0g's Avatar
Oswego , Illinois
I would start from the top and work your way down. Perform proper reseal/replace of all roof openings. As you know, there are ,many threads on each item. Use the Google search function.
IMO, take your time and do each one right. It's worth the time and money to go first quality on sealing out the water.
-Rich-
Old 03-25-2013, 05:30 AM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
lots of info here:
http://www.airforums.com/forums/f456....html#post5711
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 03-25-2013, 05:38 AM   #4
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Agreed. Depending on your climate you can cover the vents with a temporary covering until you get to them. I use kitchen trash bags and 3m package sealing tape. I use 3m package tape on the windows too. Yep it's quite an ugly sight but we have had 32 inches of snow here this winter and my trailer is stored outside.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-25-2013, 05:42 AM   #5
eljay's Avatar
1968 24' Tradewind
Looks like this.
Eljay
Old 03-25-2013, 06:03 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
ThAnks for swift help my friends!
Post was sorta out of shock...
Will be following your suggestions!
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-25-2013, 06:07 AM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The Roof Rats are 2 of our sons... Here are a couple pics to document:
Channing
WBCCI# 30676
Old 03-25-2013, 06:16 AM   #8
eljay's Avatar
1968 24' Tradewind
Nice work space! Handy roof rats. Looks like you'll have all those leaks fixed in no time!
Eljay
Old 03-25-2013, 07:16 AM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks! No doubt I am blessed!
Channing
WBCCI# 30676
