Old 03-25-2013, 09:18 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Mjolnir carpet removal
With some significant encouragement from a recent friendly visitor, I am going to replace the carpeting...
Thanks, to my new friend...
Ok.. so, do I cut around the perimeter with sharp razor then just lift out the old carpeting? What is the collective experience?
Old 03-25-2013, 09:36 PM   #2
r carl's Avatar
Lin , Ne
Lots of pulllling!!!!
Old 03-25-2013, 10:16 PM   #3
1974 Argosy 20
Kooskia , Idaho
The ones I have removed used household type carpet tack strips around the edges. The prongs on these strips are always sharp and often very rusty. If you are not wanting the original carpet for a pattern, cut it about 6" from the edge and take the center out, then pull up the edges, then remove (very carefully) the rusty carpet tack strip.
Sometimes you will find the carpet has been put in first, then the cabinets put in over it. In that case you will need to cut around the edges to get the carpet to release.
Old 03-26-2013, 09:56 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
idroba.. carpet appears to be under all the furniture... so...... time to get fresh load of carpeting razor blades..
Carpet replacement in bedroom idmtman Upholstery, Blinds, Walls & Interior Finishes 1 12-28-2011 09:17 PM
Dyed carpet paml Land Yacht/Legacy Motorhomes 2 10-12-2011 07:06 PM
