Old 02-07-2014, 09:42 AM   #1
1995 30' Excella
Arvada , Colorado
wiring schematic
Just bought a pristine 1995 30 and haven't even picked it up yet. It is sitting in AZ waiting on me !!! I'm new to the forum and new to Airstreams, but looking forward to both.
Does anyone have a wiring diagram for my trailer they could send me? It sure would be helpful in checking things out and getting to know the unit..
Anything else you guys think I should know as a new Excella owner would also be greatly appreciated.
thanks
bob
bobj0694 is offline   Reply With Quote
Old 02-07-2014, 09:59 AM   #2
thanks
bob
A schematic for what?
The trailer or for the 12 volt connector cable?
Old 02-07-2014, 10:56 AM   #3
1976 27' Overlander
Hartford , Alabama
I was lucky and mine came with a service manual. If I was you I would order one and read it cover to cover. It has wiring diagrams, all kinds of instructions for disassembly that will save you hours, and detailed instructions for every system on the trailer. Wouldn't be without one.
Tom J
Valacidor is offline   Reply With Quote
Old 02-07-2014, 12:05 PM   #4
1995 30' Excella
Arvada , Colorado
For the entire trailer, but you bring up a good point. I have a seven blade on my truck and assumed the airstream would be pretty standard and I would just plug in and go.. Would that not be the case..
thanks for helping a rookie
Old 02-07-2014, 01:16 PM   #5
Not necessarily will the two match.
Old 02-07-2014, 11:24 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Seven round terminal or seven flat terminal?
It seems to me that in RV use seven flat is the standard, and that in general they follow standard protocol from the factory, but you never know when an individual owner will deviate from standard fare and switch things up.
Whatever someone has done, I always recommend returning to standard pin placement in the plugs.
That said, the wiring between the plug and lights on my 72 was just the tip of the iceberg of the 12V wiring... (There are a lot of wires in these campers) So I ripped it all out and went with a more simplistic plan...
Total wiring schematic joneslacey Electrical - Systems, Generators, Batteries & Solar 3 06-07-2012 09:20 PM
Wiring schematic: 1969 Overland. edglenn Electrical - Systems, Generators, Batteries & Solar 3 09-15-2011 07:17 AM
Wiring diagram / schematic for a 76' Sovereign gronlampa Electrical - Systems, Generators, Batteries & Solar 1 09-07-2011 08:38 PM
Wiring Schematic for '68 Ambassador 29? Silver Suckr Electrical - Systems, Generators, Batteries & Solar 1 07-23-2011 11:13 AM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
