Old 08-16-2009, 08:01 PM   #1
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
VIN Decoded
I used the VIN decoder found here on the forum, and the math etc, turned out just as it should; check digit matched the title, and mathematically worked out as it should. The only thing is that according to the vin, I should have a center bath, rear kitchen, (code A) whereas I have a center bath curbside and the kitchen is just behind the door curbside.
any ideas?
it really isnt important, just information, that's all
thanks.
ol' bill the newbie
wmarsha is offline   Reply With Quote
Old 08-16-2009, 09:39 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Bill. Let's see... http://www.airforums.com/forums/f238...tml#post445047
You're right and 'A' is not what you have. You're in good shape since the embossed VIN on the badge probably matches that on your title -- avoiding the bigger hassle with DMV. I've seen posts about similar occasional errors.
5 meter Langford Nahanni
Another help with VIN # Jeff3298 Title, VIN & Registration 2 12-07-2008 11:49 PM
help with vin # TJBrigade Title, VIN & Registration 1 10-19-2008 09:26 PM
Vin ID JBK Title, VIN & Registration 6 11-20-2006 08:00 PM
Vin # Help! pfay Title, VIN & Registration 23 01-19-2006 06:16 AM
VIN Help Stinky Title, VIN & Registration 0 11-12-2003 04:13 PM
