Old 07-01-2013, 11:40 AM   #1
1996 34' Excella
Enoree , South Carolina
soda blasting
Hi. My 96 wb has bad clear coat peeling. Has anyone ever tried or thought of soda blasting the panels to remove all the clear coat. Anyone have any opinions on this procedure?.
1mackenzie is offline   Reply With Quote
Old 07-01-2013, 11:49 AM   #2
Don't !!!
Use a good paint remover, and nothing else.
Old 07-01-2013, 12:07 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I just did the interior. It will leave the panels mat finish...not a real nice mat either. It is best to strip them.
Old 07-01-2013, 12:24 PM   #4
65CV's Avatar
Western , Massachusetts
I have used a small soda blaster on small parts and find the process quite slow. Many use Aircraft Stripper or Marine Stripper to remove the clear coat. I had good luck with the former, but it is quite nasty.
You may also want to search the forum on Removall, noting that it has a new formula.
65CV is offline   Reply With Quote
Old 07-01-2013, 01:52 PM   #5
1996 34' Excella
Thanks for the advice. Thats a def NO on the soda blasting. Any ideas on the best stripper to remove the clear coat?
Tks in advance
Old 07-01-2013, 02:03 PM   #6
1996 34' Excella
Any alternatives to removall, or is that the best stuff to use?
Old 09-25-2014, 07:13 AM   #7
1996 25' Excella
Tillsonburg , Ontario
When we had our '89 domes and roof areas polished and re-coated they masked off all the areas they did not want to strip, sprayed it with paint stripper...smelled like methylene chloride to me, left it sit for 20 minutes and then they power washed it.
I agree on the NO for soda blast. Although it is effective at taking just about anything off any surface the final look is always 'mat'. We used Soda to clean equipment in our plant.
JCWDCW is offline   Reply With Quote
