Old 01-18-2015, 04:37 PM   #1
Sioux Falls , South Dakota
How to tell the difference
In 1995 Airstream made both wide body and standard body coaches with the same name. The spec page does list both, but is there an easy way to tell from a picture whether a particular coach is standard or wide body?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 01-18-2015, 04:47 PM   #2
SteveH's Avatar
Common Sense , Texas
The easiest way I have found is the upper center panel is obviously wider looking.
Regards,
Steve
Old 01-18-2015, 06:26 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Ditto first response. Don't know if the same held true then, but since 2005 everything 25 feet and up is a wide body, everything shorter is 8 feet wide.
Paula
Old 01-18-2015, 06:32 PM   #4
Thanks. That's exactly what I'm looking for.
TAC SD-6
AIR 54240
Old 01-19-2015, 07:29 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I do believe that on the serial number plate in the "Model" line there will be a "W" behind the number.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 01-19-2015, 11:20 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
On the newer trailers, the wide body (25' and up) are obviously wider to the eye- the window at the front of the trailer is wider. This is especially noticeable on trailers with panoramic windows. The frame rails are set at different widths. The slinky storage is further up under the trailer. The stabilizer cranks are set further up under the trailer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-20-2015, 09:36 AM   #7
SteveH's Avatar
David was asking how to tell the difference at a glance, and another way once you get used to looking at them is the wide bodies seem flat on top compared to the earlier models.
Regards,
Steve
Old 01-20-2015, 12:30 PM   #8
m.hony's Avatar
2013 30' Classic
The more narrow front window is obvious from a distance. Single axle vs. double axle is noticeable from a distance.
TAC #MS-10
Airforums #70955
'93-95 Legacy/Land Yacht, what's the difference in these models? KOG Land Yacht/Legacy Motorhomes 1 05-27-2006 09:07 PM
What's the Difference ? Bfrank Our Community 7 08-10-2005 01:17 PM
Where's the difference? azflycaster Airstream Trailer Forums 2 06-11-2005 11:20 PM
What's the difference? IceKing02 1981 - 1983 Excella 0 08-27-2004 11:22 PM
the Airstream Difference Big Dee Our Community 5 01-29-2004 06:47 AM
