Join Airstream Forums Today
Old 02-28-2011, 11:05 AM   #1
MJBear's Avatar
2007 25' Safari FB SE
Bemus Point , New York
Excella problem years?
Not sure where to post this, but we are considering a 34 Excella to keep in the south for winter use and travel. We were told by a long time Airstreamer that we should avoid newer than 1993 through ??? He stated there were severe structural problems for a few years - not sure how long. Then it is his belief that they corrected these and made them much stronger. Is this general knowledge? If it is a fact, how do we find out what years are safe?
Thanks for any help, Mary Jane
MJBear is offline   Reply With Quote
Old 02-28-2011, 11:42 AM   #2
Be Calm, Have a Cupcake
Secguru's Avatar
1998 34' Excella 1000
Willis , Texas
We have a 1998 34' Excella 1000 that has no problems whatsoever. We think it is a wonderful coach. However if you are going to use it in the south, I recommend adding a 2nd 13,000 btu A/C in the bedroom.
Either put a wall-mounted control next to the bed or use one with a wireless remote. Be sure to have a drip tube run down. Don't let it drip onto the aluminum.
Everything else, wonderful coach.
Secguru
Would you rather have a mansion full of money or a trailer full of love?
Secguru is offline   Reply With Quote
Old 10-03-2011, 09:01 PM   #3
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
I have a 1995 Excella 1000 34 ft. I know of no problems except the upholstry coming loose in the living room area. I just put it back with plastic lattice strips and screws. I is neat.
Why settle for anything less?
1995 34ft Classic Excella 1000
2011 F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
Old 10-03-2011, 09:25 PM   #4
moderator
Brandon , Mississippi
Actually...when did they start installing the padded ceilings that fall out?...about '93?
Gee, none of them are 'show stoppers' and they all leak.
We are thrilled with our '91...leaks did cause problems with the floor...
http://www.airforums.com/forums/f205...num-54749.html
'95 started the Wide Bodies?
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-03-2011, 10:03 PM   #5
Mr & Mrs S's Avatar
Newton , Texas
93 Excella
We love our 93 29 footer, only thing is I wished it didnt have OSB for the sub-floor. Padded ceilings? Ive been told Im crazy but I dont think we have the padded ceilings. I might should have them but thats another story........
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Old 10-03-2011, 11:53 PM   #6
66Overlander's Avatar
1955 22' Safari
1962 22' Safari
1963 28' Ambassador
Oakland County , Michigan
Images: 41
Padded ceilings began in 1994 along with the shell shape change and other constuction technique changes (e.g. use of adhesive between the outer skins and ribs and therefore less rivets). The foam backing will probably eventually fail on all such units and the padding will then droop. Ours made it 16 years before it drooped last year on our 1994 28' Excella (that we sold earlier this year), but we tacked it back up with buttons screwed to the inner skin and it looked fine. I have seen others that same age that haven't drooped yet and other newer Airstreams that drooped sooner. Re-gluing a drooping padded ceiling back up is apparently not a viable long term option. Airstream told us that to "fix" it they would remove the interior skin panels and replace them with new aluminum and then apply new padded ceiling material to the new skin panels - definitely not an inexpensive proposition. We opted for the buttons.
Someone once told me that the early 34' front kitchen models (which I think started in about 1994 or 1995), may have had structural issues with droop rearward of the axles, but I never saw proof of that theory. He claimed that later 34' front kitchens (about 1996+) were reinforced and didn't have the issue.
I have never heard of other structural issues on 1994 and newer Airstream other than some frame cracking rearward of the axles on certain early to mid 2000's 22' models. Of course, that does not mean there weren't other issues that I am not aware of.
Not structural, but I have heard of some limited breakage issues with the frameless windows that also began to be used in 1994 (e.g. breaking when open in a strong wind), but this does not seem too common. I think this concern likely affects all units with frameless windows up to brand new Airstreams.
Other than that, I do not know of any specific problems with 1994 and newer units, but I am certain that each age of Airstream has it's own issues. Ask questions. Become educated. Properly inspect any used Airstream you consider buying for the typical problems associated with that age. Then make your best educated decision.
Joe
WBCCI/VAC #6768 (previously 5533)
'55 22' Safari / '62 22' Safari / '63 28' Ambassador
Currently Looking for . . .
1. An early 60's front panel battery box
2. A late 70s/early 80s 27'-31' Airstream
66Overlander is offline   Reply With Quote
Old 10-04-2011, 12:24 AM   #7
ernesto ca's Avatar
1994 34' Excella
Arabela , New Mexico
I have the same problem with that drooping ceiling ..What kind of plastic lattice strips are you referring to because I would like to fix it. the spray adhesive did not work...thanks ernesto
ernesto ca is offline   Reply With Quote
Old 10-04-2011, 12:43 AM   #8
LawChick's Avatar
1992 29' Excella
Morrilton , Arkansas
Images: 33
We love our 1992 Excella Classic 29'. Yes, we had some soft spots in the floor, which we fixed. She's full of hardwood, has a big ole cedar-lined double door mirrored closet, gleaming parquette floors. Wouldn't trade her for anything.
All her systems work. We put on new brakes & shocks, and have pulled her well over 6000 miles in the last 9 months. While we wouldn't trade her, we may add a smaller one to our collection someday. It won't be a new one.
Oh, and we've been in her during a storm which uprooted huge trees and did major damage on the other side of the park, and have weathered two hailstorms. She didn't rock or leak, and the hail dents added to previous ones just added to her character.
I am as comfortable in "Esmerelda" as I am at home. We bought her cheap and spent a little fixing her up. Between $2,000-3,000. There's a lot more that could be done. But for now we're more interested in using her than completely restoring. She's got some dings and cosmetic issues here and there, but then, so have we.
Having said all that, when you look at late 80-early 90s models, look for telltale signs the rub rail has popped loose in the front. These models can have front end separation. It had begun in ours, and we fixed it before it got out of hand. Check the forums for more about what to watch for. We popped some front rivets, which led to discovery.
But...gitcha' one. They are the coolest things ever!
Carol
2004 Dodge Ram 2500 Cummins Turbo
"Live the life you've dreamed."
-- David Henry Thoreau
LawChick is offline   Reply With Quote
Old 10-04-2011, 03:34 AM   #9
2001 exHella
I bought a 2001 25 foot excella (new). At least, I think it was new. I didn't know a thing about shopping AS's or any RV for that matter. I had it home a couple of weeks and walked in to find a flood. Water coming in from the bathroom fan. I looked better at the AS and the carpet was not factory. The radio looked like it had been replaced at some point and a missing piece of glass from one of the top cabnets. The couch had preivious water stains on it from a different flood. I believe it was left on the lot and someone took what they needed from it until they fixed it up enough to sell it to an idiot--me. Last year, more floods. Rear floor rotten. Gutted it and found at least 6 different leaks. Most notably, it was pointed out to me that the curb side top/rear outter skin had rivots that were not factory. I just about have it put back together. There was so much Vulkem put into sealing it up that all my belongings, myself and my dog reeks of chemicals all the time. it has been airing out for several months -- to no avail.
I bought this AS in Brooksville,FL from a dealer.
I say don't buy one unless you can aford to rebuild it.
lightng is offline   Reply With Quote
Old 10-04-2011, 04:01 AM   #10
sandlapper's Avatar
1993 34' Excella
york , South Carolina
We love our '93 34'. Have had no problems that I am aware of. 93 is arguably the last great year for Airstream. 94+ are widebody, less rivets, 2 piece rib rather than 1 piece, ceilings that fall, more plastic. We wouldn't have anything else. Thay ALL leak at some point in time. Up to the owner to stay ahead of it.
Have a friend who owns a +- 96 model 34. His does have a crack in the outer skin running sort of diagonal from the corner of the door, about 4-5" long. Could be a structural thing, who knows. Mine pops a rivet occasionaly in the same area on the inside. Long trailer, rough roads, especially bridges, more flexing.
If I'm not here, I'll be somewhere else.
2007 Dodge Crew Cab 6.7 Cummins 6 speed manual DRW factory installed optional exhaust brake Leer Cap
12 Tires on the ground
Are you kind?
WBCCI # 3892
AIR # 43788
John & Susan
sandlapper is offline   Reply With Quote
Old 10-04-2011, 04:35 AM   #11
1977 31' Sovereign
1989 34' Excella
McHenry , Illinois
Two International presidents over the last 5 years had their 34's develop tail drag. They both had the elephant ear fix installed in them. The trailers were late model wide bodies. They were using Equalizer hitches and putting on a lot of miles. Our 1989 model has a lot of miles and pops a rivet now and then. It is a long trailer with big overhangs, so the stress in the frame over the wheels gets high, if you encounter rough roads. We do not have the padded ceiling so do not have that problem. Any vehicle that uses urethane foam as a structural support will encounter problems because urethane's strength declines with age and will fail. Look at all the car ceiling repair places in Florida. I wonder how long it will be before the urethane foam bonding tape that started to be used in the late model trailers to replace many of the rivets will start to fail?
Old 10-08-2011, 06:46 AM   #12
Skatiero's Avatar
1989 29' Excella
Marietta , Georgia
We love our 1989 29'. No padded ceiling. It has USB floors, though.
Skatiero is offline   Reply With Quote
Old 10-08-2011, 07:49 AM   #13
DKB_SATX's Avatar
1975 Argosy 24
Fort Worth , Texas
I wonder if that was a typo or auto-correct. I think you mean OSB, unless you plug your iPod into the floor.
Il Carriaggio -- 1975 Argosy 24
2007 F150 Lariat Supercrew 5.4
AIR# 15566 | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire.
-- Sir Winston Churchill
Old 10-10-2011, 09:17 PM   #14
Foevrluvinit's Avatar
1986 34' Excella
Patrick AFB , Florida
1986 34' Excello
I'm considering purchasing a nice 1986 34' Excello. Seems to have no problems. No blemishes in the skin, all systems seem to work, new tires. Anyway, I wondering how much I should pay for it and are there any areas I should focus on for possible problems. Their asking 10 thousand. I appreciate all responses and I'm new to the threads so please bear with me. Thanks, Scott
Foevrluvinit is offline   Reply With Quote
1988 Excella 32' GVWR Confusion! Rob&Julie Towing, Tow Vehicles & Hitches 26 03-17-2012 02:06 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
