Join Airstream Forums Today
Old 10-11-2011, 07:21 AM   #15
Aviator's Avatar
1997 34' Limited
South of Atlanta , Georgia
Scott,
If everything is in good shape, the equipment works and the floors are solid (rotted floor is a sign of leaks), I would think 10K is reasonable.
Our is a '97 34'. The floor is plywood not OSB. The ceiling did fall due to an OSHA mandated adhesive change. (The OSHA approved adhesive breaks down at 97f. Try keeping the inside temp below that in storage!) We had screws and buttons installed in the entire ceiling (not just the saggy part) and it looks good. I haven't seen any evidence of separation (even though I have drug the tail a couple of times by accident)
Craig and Carol
1997 34' Excella 1000
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Aviator is offline   Reply With Quote
Old 10-11-2011, 07:43 AM   #16
kellywood's Avatar
1986 32' Excella
Wolfe City , Texas
Images: 14
I have an 86 32' Excella and would not take for it. Yes it did have some problems but mostly due to previous owner neglect. All exterior / structural seems to be in good condition. Replaced all upholstery, repaired floor in two areas, replaced toilet, and now it is like new. Not bad for a 25 year old model. Best of luck in your search for a home away from home.
kellywood is offline   Reply With Quote
Old 10-11-2011, 11:39 AM   #17
Foevrluvinit's Avatar
1986 34' Excella
Patrick AFB , Florida
Thanks for the input so far and we will look at the cielings. I have noticed they are very sticky. I was thinking someone may have fried food during their stay but I believe it may be the adhesive you're talking about. It may be bleeding through. Great feedback and again, thank you. I hope to hear more. This site is excellent so far!
Foevrluvinit is offline   Reply With Quote
Old 10-11-2011, 09:17 PM   #18
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
Originally Posted by ernesto ca View Post
I have the same problem with that drooping ceiling ..What kind of plastic lattice strips are you referring to because I would like to fix it. the spray adhesive did not work...thanks ernesto
I went to Lowes and got some white plastic strips 8' long and cut them to fit arched across the interior. I fastened them with white screws through the inner aluminum shell. it held the vinyl in place very well and looked neat. Cost was less than $20.00 ant the time was less than an hour. Lowes calls the plastic strips "lattice strips." They can be cut with a razor knife very easily.
Why settle for anything less?
1995 34ft Classic Excella 1000
2011 F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
Old 10-17-2011, 04:51 AM   #19
1977 31' Sovereign
1989 34' Excella
McHenry , Illinois
A 1986 Excella will have the vinyl laminated ceilings and will eventually get sticky due to the "spewing" of the plasticizer. This is covering in a number of other threads and can be cured by properly cleaning the ceiling and then sealing it with "Future" acrylic floor polish.
Old 10-17-2011, 06:02 AM   #20
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
34' have there own set of issues due to the added weight and the third axle, but our 1998 31' Excella, has plywood floors and hasn't had any issues with the ceiling padding falling. I don't know of any other long term issues, except maybe the water that collects in the storage box on the tongue, which causes them to rust out.
Damon
damonbeals is offline   Reply With Quote
Old 02-10-2012, 02:00 PM   #21
I have a 95 - 34' Limited that I bought in 2003 and have not had any problems. No drop ceiling nothing that the Oregon coast didn't cause. It is for sale and you can see the pictures showing it has held up very well. We also had a 92 - 32' and it was great. I have heard the story about the "last good year was?" but that year has moved around. Do your homework and have the AS thoroughly checked out and stay on the maintenance
lmcatee is offline   Reply With Quote
1988 Excella 32' GVWR Confusion! Rob&Julie Towing, Tow Vehicles & Hitches 26 03-17-2012 02:06 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
