Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1994 - 1996 Excella
Old 04-16-2007, 08:10 PM   #1
sander17
sander17's Avatar
Profile:  1996 28' Excella
Okemos , Michigan
Images: 42
96 Excella Upgrades
We decided to do a few upgrades to our 10 year old 28 ft Excella. The biggest part of the project was a reconfiguration of the "living room" area.
First, a photo of "before"
Name:	Original Layout.JPG
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 04-16-2007, 08:16 PM   #2
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
The Dometic Refrigerator broke the hinge on the lower door. The first photo is of my temporary fix with a strap of steel and a couple of sheet metal screws. The second is the much better looking solution, a whole new lower door. The hinge was part of a large piece of plastic forming the whole door frame.
ID:	35720  Click image for larger version
Name:	New Refer door.jpg
Dave
Okemos, MI
AIR#2276
Old 04-16-2007, 08:22 PM   #3
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
Goodbye old Mr. Buzzy
After many years listening to the hummm of Univolts, it was time to upgrade to a power converter that was designed in the LATTER half of the 20th century. On our previous Airstream, I had to lift the beast out once to replace the two blown capacitors. What a monster! Goodbye Mr. Buzzy, Hello to a WFCO 3-stage converter.
Name:	Old buzzy Univolt.jpg
ID:	35722  Click image for larger version
Name:	New WFCO 3 stage charger.jpg
Dave
Okemos, MI
AIR#2276
Old 04-16-2007, 08:25 PM   #4
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
Potty Time!
The original Thetford plastic toilet was showing its age, so a Sealand Traveler Lite was in order. We chose the Sealand based on such good reviews on the forum.
Name:	Goodby Mr. Thetford.jpg
ID:	35724  Click image for larger version
Name:	Hello Sealand TravelerLite.jpg
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 08:08 PM   #5
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
Building a box around the Batteries and Univolt
Since the gaucho (jacknife sofa) was going to be moved to the streetside wall, I needed to cover up the Univolt and the two battery boxes. The first photo shows them after the carpet was removed and the gaucho shifted. The others show the fabrication of the red oak box (plywood and left-over solid from other projects).
ID:	35817  Click image for larger version
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 08:14 PM   #6
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
Dinette style bench
We wanted better seating than the single floating chair, so I built a dinette style bench, once again with oak plywood and solids. I stained it with Minwax red oak stain and finished it with oil based polyurethane. The seat and the back are removeable, with cabinet magnets to hold them. This gives good hidden storage without a visible door.
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 08:21 PM   #7
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
Flooring
A local manufacturer, Launstein Hardwood Floors, sells 3/8" thick hardwood flooring in several different widths. I have installed several of these floors in two houses, so I was familiar with the technique and had the necessary tools. The boards come pre-sanded and are attached with 18ga pin nails and construction adhesive.
The 96 Excella had an oak hardwood floor already in the kitchen area. It measured 5/8" above the main plywood floor. So, the first step was to install 1/4" underlayment everywhere. Unlike the other "nominal" thicknesses of plywood at Home Depot (which are typically 1/32" off the correct thickness), the 1/4" was actually 1/4" thick.
ID:	35821  Click image for larger version
Name:	Launsteins Red Oak Shorts.jpg
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 08:28 PM   #8
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
Floor installed and stained
The floor went quickly. The only tough part was running the furnace, eating up lots of propane, to keep everything at greater than 60 degrees. The two photos show the floor, pre-stain and after the Minwax red oak stain was applied.
ID:	35823  Click image for larger version
Name:	The Stain Goes down.jpg
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 08:33 PM   #9
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
Floor after poly and trim
I put down 4 coats of Fabulon oil based satin finish polyurethane for floors. It is the finish recommended by the flooring manufacturer. With the long drying time, it is tough to get it to dry without dust landing in the wet poly. I may switch to water based floor poly next time. I'll have to do some tests first.
ID:	35825  Click image for larger version
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 08:38 PM   #10
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
A new table
Since we removed the old Airstream folding tables, I needed a new one between the gaucho and the new bench. Back to Home Depot for more oak plywood. For a removeable support, I used a marine table mount manufactured by Todd and sold by West Marine. The local store did not stock them, but the warehouse shipped it for free within a couple of days. (Sorry about the orientation of the first photo)
Name:	dinette and bench 003.jpg
ID:	35828  Click image for larger version
Name:	Table with Todd post.jpg
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 08:45 PM   #11
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
New Upholstery
The old upholstery on the gaucho was showing its age, and we needed new cushions for the bench and the box covering the WFCO converter and the battery boxes. So after being turned down by several custom upholsterers (You want cushions for a trailer???), we finally found one in a nearby town who would do the job. She recovered the gaucho and made the new cushions with the bottom covered with vinyl (we have a 5-year old). This allows us to flip them over during major potential spill times.
Name:	dinette and bench 005.jpg
ID:	35830  Click image for larger version
Name:	dinette and bench 018.jpg
Name:	New upholstery.jpg
ID:	35832  Click image for larger version
Name:	dinette and bench 004.jpg
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 08:49 PM   #12
sander17
sander17's Avatar
Okemos , Michigan
Images: 42
What's next?
As you can see from the above photo, I need to fabricate a wood panel to cover the end of the gaucho, where you can see the side of the drawer. At some time, I would like to refinish the kitchen floor to match the new.
BUT FIRST! TIME TO GO CAMPING!!!!!!!!!!!!!!!
Dave
Okemos, MI
AIR#2276
Old 04-18-2007, 09:06 PM   #13
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Nice, I like a personal touch inside! Nothing like a full time dinnette! DG
Wherever we want to go
We go
That's what an Airstream is
You know
It's not just a frame, aluminum skins
and wheels.
That's what a Airstream needs
not what a Airstream is.
What a Airstream is,
is Freedom.
Proud Appellation American
doorgunner is offline   Reply With Quote
Old 04-19-2007, 07:27 AM   #14
GT1963
LADYBUG
GT1963's Avatar
Profile:  1963 19' Globetrotter
2005 22' International CCD
Lakefield , ON
Images: 59
Gishhhhh I'm tired just looking at all that work! and fabulous work I might ad - had the pleasure of seeing it in person....
What a great job and so much more functional than the couch and side table. That so many Airstreams have.
If you get tired of the big square table, with your skill you could muster drop leafs in the future - you know for when the Rivettes arrive and want the table to be their cocktail table instead of the full game board or meal table. But it is a table to die for for little Sam I could see lego masterpieces being built!
How about that hydraulic post the movie guy from Sahara is getting now that would be cool for Sam - while M & D are getting dinner ready he can lower the table to play height.
The spot beside the couch lends itself for an extra cupboard and counter.
Great job Dave!
Streaming in the spirit of Exploration...
"To go places and do things that have never
been done before-that's what living is all about."
- M. Collins
Peter & Sharon
WBCCI #1963 & 1961
GT1963 is offline   Reply With Quote
