Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1990 - 1993 Excella
Old 12-16-2015, 09:20 AM   #1
1990 29' Excella
Ft. Myers , Florida
Where's my grey water valve?
First time Airstream owner of a 1990 Excella 29...I only see the bigger black water valve but not a smaller gray water valve....I assume theres just one valve to empty both simultaneously on this model??
Thanks!
FSUeyedoc is offline   Reply With Quote
Old 12-16-2015, 12:52 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
There should be two pull handles.
CRH is offline   Reply With Quote
Old 12-16-2015, 01:31 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
There are, or at least should be, two valves, one for black tank and one for gray tank. One thing I can think of is maybe sombody added a 3rd valve on to the hose hook up connection. This 3rd valve is sometimes added when one of the other valves leaks. So look to each side and behind of the single valve to see if there are not 2 more valve handles or at least a box and place where the valve handles were. I think it likely someone had valve trouble and "fixed" it with a 3rd valve. I would surprised if it left the factory as a one valve model. Both the original gray and black water valves are the same size and reside well under the trailer in an enclosed area with a handle through a little box on each side of the hose connector. So if you can actually see a valve it is a add on.
Leaking grey water flush valve PAL07 Waste Systems, Tanks & Totes 10 05-31-2015 07:14 PM
Grey water outlet doesn't have valve mhilley Waste Systems, Tanks & Totes 2 07-09-2014 06:53 PM
grey water dump valve won't open adonh Sinks, Showers & Toilets 15 04-06-2013 09:46 AM
grey water valve repair john hd Waste Systems, Tanks & Totes 33 12-21-2010 04:30 PM
'86 345 MH Grey Water Valve Extension Jim Tyrney General Motorhome Topics 1 11-17-2003 08:50 PM
