Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1990 - 1993 Excella
Old 03-16-2008, 03:21 PM   #1
osolow's Avatar
Profile:  1990 29' Excella
riverton , Kansas
Cool outside lights
i have been replaceing bulbs on my 91 29ft excella and of course most of the bulbs have rusted and broken and the fixtures aswell.
now i need to find a few of the fixtures (porch light step light and the two on ether side of the door) is this somthing i will need to go to A/S for. Or should i change them and possible have to due some cutting on the body?
Now for a gripe i removed a couple of the fixtures, first i could not just be unpluged due to ether the plug was ether to far up the back side of the wall or they are hard wired straight to the light fixture. and now the problem is when i go to replace them it's going to be a bear due to the limited amount of slack in the wires. last but not least the made in taiwan sticker on the cheap pot metal fixtures. i would think the price that these airstreams are bringing new or used they would have been put together with a little higher quality parts and they would engineer these things knowing the will need to be worked on and parts replaced.
dont get me wrong i love my airstream i just have a few complaints
osolow is offline   Reply With Quote
Old 03-16-2008, 03:47 PM   #2
I Wanna Go Full Time!!!
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 16
Check out Vintage Trailer Supply Lighting Section
Osolow,
You might be able to find exact replacments in the exterior lighting section at Vintage Trailer Supply. As for no "play" in the wires, I would suggest cutting them as close the the old fixtures and maybe splicing a length that will get you the "play" you desire.
I too had many busted / cut knuckles while trying to replace my exterior light fixtures on my '87 .
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package
1987 34' Excella 1000
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 03-16-2008, 04:30 PM   #3
osolow's Avatar
riverton , Kansas
Cool lighting
the vintage place had a couple of the lights i was needing, and in L.E.D which i was wanting to switch to. but the porch light assembly i will need and the lights next to the door. here some pictures of what they look like if any one out there know were i could possible find them that would be greate
Name:	airstream lights 012.JPG
ID:	56347  Click image for larger version
Name:	airstream lights 011.JPG
Old 03-16-2008, 04:42 PM   #4
DEITZ645's Avatar
1987 34' Excella
Images: 16
Back To Vintage Trailer Supply
Osolow,
The round 4" porch light can be had at Vintage trailer supply too here...
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
As for the step light, you may need to get that from an AS dealer. Have you considered re-plating the exisiting fixtures???
You may also want to look at a local auto / truck supply shop for your lighting needs. They are all pretty much standard light fixtures. I was able to get marker / clearance and the 4" porch light locally which saved me a few bucks in shipping and the actual cost of the lights.
As for quality, I think they are all bout the same, not very good .
AIR #14487
WBCCI #7429
Old 03-16-2008, 04:47 PM   #5
osolow's Avatar
riverton , Kansas
Cool step lamps
i could but i would have to rewire and figure out how to hold the bulb in the houesing due to it rusted out. i wounder if i could mount a 4 inch clear L.E.D in the porch light spot ?
Old 03-16-2008, 05:02 PM   #6
DEITZ645's Avatar
1987 34' Excella
Images: 16
Found Step Light
Osolow,
I have the same step light on my '06 so I ran down to the field where I have it stored and there is a label inside the fixture identifying the manufacturer as JRV Products and it is a model T67. Hopefully that will help you in your quest to find a replacment.
AIR #14487
WBCCI #7429
Old 03-16-2008, 06:44 PM   #7
osolow's Avatar
riverton , Kansas
thanks
i do appreciate
i e-mailed them and will see what happens
Old 03-18-2008, 05:34 PM   #8
osolow's Avatar
riverton , Kansas
Cool lights found
i found the lights i was looking for today at a local RV salvage yard (Colaw) its out side Carthage Mo. they had every thing i was needing plus some. i also got to see what airstreams they had there. they had about 20 or so A/S they all looked pretty well picked throw, but there might be some good body parts or other odds and ends some one might need.
Pingbacks are On
Need help with lights spat61 Land Yacht/Legacy Motorhomes 1 10-10-2007 06:21 PM
no lights kelly1 Electrical - Systems, Generators, Batteries & Solar 1 09-24-2005 09:33 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
SEO by vBSEO 3.1.0
