Old 08-01-2011, 08:24 AM   #1
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
Exclamation Potential Problem? Pictures included
Hello Experts,
While installing shelving in my cedar closet in my '92 Excella, I discovered what MIGHT be a problem. At the bottom of the closet, the back wall has separated from the side wall leaving a gap. Additionally, there is a similar problem in the kitchen by the sink - wall separating from outside wall.
IS THIS A PROBLEM? It has me worried about frame stuff.....I don't see the problem anywhere else. See pictures:
ID:	136456   Click image for larger version
palmtreegirl is offline   Reply With Quote
Old 08-01-2011, 10:21 AM   #2
Originally Posted by palmtreegirl View Post
Hello Experts,
Yes, unfortunately, your Airstream has a "BAD" problem.
The walls separating from the shell, is caused by excessive flexing of the shell, and/or vibration.
Note that the failures are near the axles.
That flexing can be caused by excessively rated hitch bars, a super duty tow vehicle, unbalanced running gear, and/or axles that have had their rubber rods fail.
Old 08-01-2011, 11:13 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Do you have any black-ring or missing interior liner pop-rivets?
Wabbiteer is online now   Reply With Quote
Old 08-01-2011, 12:15 PM   #4
Medina , Ohio
What is black-ring? I haven't noticed any rivets missing. It had new axles in 2009 (according to the PO). It has a Reese weight distributing hitch and I bought the tow vehicle from the PO which is a 2002 Dodge Ram 2500 Quadcab.
Oh my - what do I do about this?
Old 08-01-2011, 12:28 PM   #5
What are the ratings of your hitch, etc.
To start with, your tow vehicle is tough enough to tow the Queen Mary.
Is your running gear balanced?
An Airstream, MUST have a soft ride, or else you pay the penalties.
Old 08-01-2011, 12:29 PM   #6
Medina , Ohio
Now, I'm thinking about this - I have only owned this camper for about 4 weeks and I don't know when this bad problem came about.
Could it be that it was BEFORE 2009 when the PO had the new axles installed?
Will the damage get worse? Should I park it until it's fixed? Is it possible that it won't get any worse now that there are new axles?
Old 08-01-2011, 01:19 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
PT Girl...
Don't obsess, don't park it....that's probably the reason the PO replaced the axle's.
Keep an eye out for pop-rivet heads laying on the floor after a trip.
Black ring= the residue from the aluminum rubbing where a PR has loosened.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-01-2011, 01:46 PM   #8
Medina , Ohio
I checked it out - did see a rivet popped off inside the cupboard (over the wheel wells) where the microwave is and saw the black ring (only one) in a rivet next to it. I looked under the floor in the closet and the inside cover of the wheel well has some cracks and breaks right along the edge where it bends to attach to the wall - it has something going on. Checked the wheel well from the outside - doesn't seem to be compromised - has some tar like stuff on it (sealer?). Is there an inside wheel cover and an outside one? I felt around the outside one and don't seem to feel any of the inside cracks.
I'm not happy about this....supposed to put her on a Ferry to camp on an island in about 3 weeks......
Old 08-01-2011, 02:00 PM   #9
Check out this thread, it's not difficult to replace the rivet, then just keep an eye out for any more.
RLC
John Prine
Old 08-01-2011, 02:12 PM   #10
Medina , Ohio
Cracks in the Wheel Well Cover (Inside)
Here is a picture of what is going on under the floor in the closet:
Could it be that I am usually boondocking so I run with a full tank of fresh water?
This is not good.
Old 08-01-2011, 02:55 PM   #11
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
palmtreegirl:
"Lost rivets are one of the first signs of out of balance tires and running gear."
Makes sense..take it for a short ride with someone riding inside..(make sure you have a 2 way radio or intercom..I don't normally advise ppl to do this, as many states have a different outlook issue with passengers in trailers while moving. in this case, it's just to check for vibrations..).
Good luck~!!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 08-01-2011, 04:08 PM   #12
Originally Posted by 53flyingcloud View Post
palmtreegirl:
Good luck~!!
Vibrations and to what degree, is a subjective opinion.
Best way to tell, is to see if the running gear is balanced properly. If not, that's a good starting point as well as observing the tire wear pattern.
Old 08-01-2011, 05:26 PM   #13
Splitrock's Avatar
Sioux Falls , South Dakota
Sometimes these trailers have been apart for whatever reason (frozen pipes is one) and they are not always returned to original condition . . . just another possibility. Is there any exterior body damage anywhere? Any signs of wreck or tree damage repair?
Old 08-01-2011, 06:03 PM   #14
A full fresh tank won't cause the cracks.
If you are unsure about whether the wheels/tires are balanced, it's worth the peace of mind to have them done. "road force balance" can be done by most good tire centers.
Quite a few here, (me incl) use the Centramatic system to keep the running gear in tune after balancing.
RLC
John Prine
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Pictures of your new trailer being assembled richinny Airstream History 1 07-29-2011 10:21 PM
Potential New Owner and Questions RV Doctor Member Introductions 24 04-01-2011 07:10 PM
Barker Super Jack Problem Luckyducks Jacks, Stabilizers, Lifting and Leveling 1 03-20-2011 08:49 AM
